Programming for lipos on MG
  • Diesel6401
    Memento Vivere
    • 4391
    Originally posted by tman52804 View Post
    What settings would you use on the seaking 180amp esc for my CC/Neu 1512, 1800kv motor?
    I have that motor. I plan on running it a default 15.00 to start. Not sure if it's right or not. I run my leopards at that timing and they like it.
    - Diesel's Youtube
    - Diesel's Fleet
    • blackcat26
      High Speed Junkie
      • Sep 2009
      • 1750
      15deg works good on mine on 6s. Neu recommends a little higher timing like 15 on the "y" winds.
      • POWERS
        • 126
        Just want to make sure the programming worked.
        I plugged the programmer in turned the on switch on and it beeped once, I turn the power off, disconnect the programmer, and reconnect the receiver. When i turn the power back on the only thing that works is the steering, pull the throttle and nothing. SO i turn it off and unplug a battery and plug it back in then everything works. Is this normal?
        • ron1950
          • 3082
          yes u have to disconect the batteries before it takes for some reason....i think its supposed to beep twice now when u turn it on if linerer throttle was selected
          • FrostyNutz
            • Dec 2010
            • 10
            Thanks Ron ,, I just scratching my head wondering why my motor wouldn't run . This site rocks
