A quick easy mod...
Rudder to Strutter conversion
Tags: None
That's really nicely done. Same idea I did this weekend. Great minds, and all that...
One thing I would recommend, however, is that you allow the standoffs to NOT pass through the strut bracket, and instead, sandwich the spacers (I'd make them out of metal) between the two halves of the strut bracket. This turns it into an "I-Beam" arrangement, making the bracket much stiffer. Might not work as well with the thin standoffs you used, due to their narrow mounting base, but with the larger ones I used, it's rock solid, and the strut brackets don't flex at all.
Either way, it's a good upgrade.Attached FilesDarin E. Jordan - Renton, WA
@Darin
We will have to agree to disagree on this one Darin. I preffer this method over the "butt joint" attachment. I've been running this mod since I got the boat, it's worked perfectly and is rock solid... It's just a copy of an Octura Strutter...
C-Ya on the Lake...
Ron
Just a recommendation... yours is just relying on one side of the bracket for torsional rigidity, mine uses both brackets and turns it into an I-Beam. Either will work.Originally posted by igottalongone View Post@Darin
C-Ya on the Lake...
RonDarin E. Jordan - Renton, WA
Actually with my union, the more load, the stronger it gets...
Both ways are plenty strong, not counting Turtles and Driftwood...
Here are some pictures of the rudder mod I did last week.
Well, I took my Cat out on Sunday and NO MORE BOUNCING! all gone! I offset the rudder to the right hand side using Octura offset rudder mounts ( two of them, one for each bolt ) moved the rudder arm to the other side and everything fit Great! Cut a piece of plastic to take up the thickness of the original rudder mount so when you tighten the screws for the Octura standoffs you do not collapse the strut brackets. The only thing I had to do was to slot the holes for the rudder arm. The cat runs much better! faster in the corners and also in the straights! You have to do this! It is worth it for the extra speed you get!There is no replacement for displacement, I guess I just have to Buzz it higher!
My Spacers are 1.625" long... I also moved the rudder forward a bit, to get the leading edge up closer to being inline with the drive dog, and out of the thrust cone of larger props, and also allows the stock steering linkage to be utilized.Originally posted by jac4412 View PostDarin, igot, how far over did you move your rudder? 1, 2 inch?Darin E. Jordan - Renton, WA
i like the octura ready to use offset spacers but cant find any on the net anywhere? anyone know wher i can find a couple of em? thanksMY RETIREMENT PLAN?????.....POWERBALL
Can you elaborate on how long those Octura Spacers are??Originally posted by 7500RPM View PostHere are some pictures of the rudder mod I did last week.
Well, I took my Cat out on Sunday and NO MORE BOUNCING! all gone! I offset the rudder to the right hand side using Octura offset rudder mountsDarin E. Jordan - Renton, WA
I have them, but for some reason they disappeared off the site. Probably because they never sold. I have to look for them tonight.Originally posted by ron1950 View Posti like the octura ready to use offset spacers but cant find any on the net anywhere? anyone know wher i can find a couple of em? thanksSteven Vaccaro
That would be cool... Let us know.Originally posted by Steven Vaccaro View PostI have them, but for some reason they disappeared off the site. Probably because they never sold. I have to look for them tonight.
Also, I was looking at both methods for doing this conversion. It might be advisable, either method, to use a brass, or otherwise "sheerable" fastener on the rudder side, lower mount. Should hold just as strong, but will let go and save the transom in the event of a turtle or other object.Darin E. Jordan - Renton, WA
