GEICO ESC beeping
  • cvlex
    • 19
    GEICO ESC beeping
    Today my GEICO arrived from OSE.
    I installed the optional flex cable and Octura x642.
    Then I rebound the receiver with my DX2S and programmed the ESC with program module.
    Battery Type: Lipo
    Cutoff Voltage: High
    Cutoff Tyoe: Idle
    Brake: On
    Timing Low
    Throttle Curve: Logarithm
    Now once I connect two 2S batteries and switch on the ESC, it beeps once and after a few second, it beeps five times.
    Is it normal?
    Thanks in advance,
    cvlex
    AQ Mini Rio (BL upgraded), Reef Racer 2(BL upgraded), PB Impulse 31, Miss Geico 29BL w. OSE upgrade flex cable and x642, ShockWave 26BL w. JETI Advance 50 Navy and x435, Tenshock Mini Eco, Starship (AKA Mini-Y)
  • Darin Jordan
    • 9446
    Battery Type: Lipo
    Cutoff Tyoe: Idle
    Brake: On
    Timing Low
    Is it normal?
    Thanks in advance,
    cvlex
    YUP! That's a good sign... go run it!! I think the ESC manual tells you what the beeps mean. Something about the number of cells or the timing setting or ?? I can't remember exactly 'cause I never pay attention to that.
    Darin E. Jordan - Renton, WA
    • tman52804
      • Apr 2009
      • 101
      Darin,
      What settings do you have for your esc?
      • Darin Jordan
        • 9446
        Originally posted by tman52804 View Post
        Darin,
        Battery Type: Lipo
        Cutoff Voltage: LOW
        Cutoff Tyoe: Slow Down
        Brake: OFF
        Timing: HIGH
        Throttle Curve: LINEAR
        Please keep in mind... I'm racing. I don't run more than I have to to complete a 6-lap race, plus run-up and cool-down lap, and any penalty laps that I may incur.
        • tman52804
          • Apr 2009
          • 101
          Bingo, same as mine!
          • cvlex
            • 19
            Thank you for your comment.
            I read the ESC manual again and found a description for Timing monitor in the Motor Timing Adjustment section.
            It reads:
            After the first "beep" wait 5 seconds (keep the throttle in the neutral position).
            The controller gives 5 sibngle beeps for soft timing or 5 double beeps for hard timing.
            I also set the throttle curve linear and the brake off.
            Thanks again,
            cvlex
            • jac4412
              FE Addict
              • Jun 2010
              • 427
              mine beeps once... The manual said it should beep after programming
              JAC4412 RC
              • Darin Jordan
                • 9446
                It depend on where your settings are... I think it only beeps more if you set the timing to high or something like that.
