15 deg is perfect for that motor. It is a "y" wind and that is the timing recommended on Neu's website towards the bottom.
Miss Geico Race Prep
This is a sticky topic.
I'de back it to 7* and see how it runsOriginally posted by blackcat26 View Post15 deg is perfect for that motor. It is a "y" wind and that is the timing recommended on Neu's website towards the bottom.
May run better there who knows. I made some timing test on my align one time and all three or 4 settings were within a few mph of each other. I was disappointed. I wanted to see a huge difference!FE BOATING: Less like a hobby and more like an addiction!
usually you will not see a huge difference but the amount of amp draw can be bigOriginally posted by blackcat26 View PostMay run better there who knows. I made some timing test on my align one time and all three or 4 settings were within a few mph of each other. I was disappointed. I wanted to see a huge difference!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Makes sense. I have never used any kind of data logging. I always just look for the smoke!
Originally posted by blackcat26 View PostMakes sense. I have never used any kind of data logging. I always just look for the smoke!
From Neu, applicable to neu/castle motors.
Settings for “other” brushless ESCs:
1) 11XX,15XX and 22XX series of motors are all 4 pole designs. 19XX series are 8 poles and the 44XX series are 12 poles.
2) Use low (0-10 degrees)or medium(10-15 degrees) advance settings for “Y” wind motors and low (0-10 degrees) advance settings for “D” wind versions.
3) Brake settings are up to the user and application.
Brushless, these 5000mah 20C LiPos have always charged to 4.24-4.28/ cell. I have been using this series for over 2 years now and in my experience with them I have learned that when they start taking less than 4.10v/cell it's usually a sign of weak cells. So far I have killed 2 packs with this boat
it's the price to pay to play, I guess.
I will try lowering the timing next time i run the 1512 and see if the battery heat dies down a bit. But I may never run it n this boat again since the outrunner runs so good. Thanks for the advice!
have you ever tried doing a balance on those packs?
not a balance charge, but a balance only on the packs
not sure if that could help those packs.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Brushless, yes. Every once in a while I leave my Common Sense Ballance Pro on each pack over night. Have not noticed any advantage of doing that.
So can you race with others using 6S on MS Geico and 1512 motor?DJI Drone Advanced Pilot
Canada
good, I think that will help the packs have a longer lifeOriginally posted by JackBlack26 View PostBrushless, yes. Every once in a while I leave my Common Sense Ballance Pro on each pack over night. Have not noticed any advantage of doing that..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
In Thread # 177's picture it looks as if the bottom leading edge of the rudder has been rounded. Is this true? And if it is, how is that working for you? I have been contemplating do just that for a while, but I haven't found any theads on this yet.Originally posted by blackcat26 View PostPicture is kinda blurry but you get the idea.
