Hey Guys... Bailed on work early on Thursday, Friday, and also ran down to the lake on Saturday morning, to test with the Miss G. The Eagle-Tree got a real workout...
Unfortunately, I was only able to make the airspeed sensor work for one session. It otherwise would not record, and seems dead now, so I'm looking into getting the GPS module...
However, it did capture a couple of pretty impressive runs...
Both of these were done using the stock motor and ESC. The only mods to the boat are as posted here: the offset rudder and the truing on the sponsons, and the upgraded contacts on the motor/ESC.
DISCLAIMER: Don't try this at home... the amp draw was WAY above the ratings for the ESC. Please keep in mind that it's part of my deal with ProBoat to test the limits, so that's what I was trying to do...
The first graph is from immediately after plugging in. I ran the motor up unloaded for a moment to get a baseline for the motor KV recorded.
The second is a clip from a 2-pass run using a Prather 230 prop. I have another graph where it shows 49mph max with this prop....
The third is a from a run of several passes using another prop. Going to keep this one to myself for now.
It works really well, and I want to play with it some more. I ran the boat in a simulated Offshore run for about 2.5 minutes, and it was breaking 40-MPH regularly. During another test... ran an average of 44-MPH with a peak of 46... (See last pic...)
I may have some video to post. We'll have to see if any of it turned out.
I REALLY like this boat!
) This would translate into around 36.85 MPH in stock trim.
