Miss Geico 29 BL Catamaran Videos
    • 9438
    #226
    Awesome Bob. Can't wait to see it.
    Bob is kicking the pants off us in our club LSO class with an SV. If he says it seems to handle well it probably does.
    Darin, is the radio that comes with the RTR just a stripped down version of what we already have?
    Oh, also, any more color scheme planned? Might get confusing when these start showing up everywhere.
    That's where number plates will work for racing. Like in Europe.
    • blackcat26
      High Speed Junkie
      • Sep 2009
      • 1598
      #227
      Ray, check out horizon hobby web site think its all there
      • longballlumber
        • 3119
        #228
        Ha.... Factor in the "drop one score" rule and we have a 5-6 man race for the crown at the end of the year!!!! It's gonna be a doozie! That class has been sooo much fun this year!
        I am excited to see this thing run too... Good Work Bob!!!
        Later,
        Mike
        • jac4412
          FE Addict
          • Jun 2010
          • 425
          #229
          Originally posted by spence72 View Post
          Terry,
          I'll bring mine out to the next club race on the 19th, I'm also curious to see how it handles in "race water".
          I haven't had a "man" prop on her yet, but I did crack 38MPH with a K45 plastic. I'm waiting for a new flex cable before I try some metal props. My initial impression is very positive. Repeatedly crossing my own wake while executing full speed left and right turns showed no tendency to upset this hull, it just cuts through and begs for more. We may have a winner here...
          Bob
          Was that with the stock setup? Interesting thats faster than with an x642
          JAC4412 RC
          • spence72
            • 8
            #230
            This was the stock setup on Hyperion 2S Lipos with the strut lowered 1/8" below factory settings. Batteries were mounted flush with the front edge of the trays. Out of the box speeds were 34MPH (no adjustments, stock prop). I'm still seeing some "bounce" at speed, although I believe it to be less with strut/CG tweaking.
            • tacticalretreat
              • 6
              #231
              I guess this is the right place to post this. First off, a big thank you to all of you. I have been lurking around here for the past couple weeks and learned a lot from you guys about Lipos and FE's in general.
              So I finally got the boat, batteries, flex shaft, etc, together and took it for a run Thursday and I love it! This is my first rc boat (I have had trucks in the past but it's been a while) and I know I have a lot to learn but wanted to share a couple vids I posted on youtube of some of my first runs (of course I've already flipped it over).
              Thanks again and enjoy!
              • ron1950
                • 3024
                #232
                looks good llove a good vid......what part of fl are u in anyway......that lake looks familular....
                • Jeff Wohlt
                  • 2716
                  #233
                  Did you not have it taped? That is a must.
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • tacticalretreat
                    • 6
                    #234
                    ron - It's lake bonny in lakeland...
                    jeff - yeah, I kinda learned the hatch tape lesson the hard way. the good news is both lids float and were easy to recover but you can bet I won't go without tape from now on!
                    • blackcat26
                      High Speed Junkie
                      • Sep 2009
                      • 1598
                      #235
                      Batteries are too far forward. Try running them halfway off the back edge of the tray.
                      • spence72
                        • 8
                        #236
                        Thanks for the tip; I’ll be trying it as soon as I finish flattening the ride pads. Have you tried her in “race water” or chop? Any tendency for blow overs with batteries further back?
                        • stringfly
                          • 88
                          #237
                          Battery placement
                          blackcat 26,
                          I tried the batterys back like you said and the bouncing was worse. I am running with 2 -2s turnegy 5000mah packs but with stock prop. (have a x640 and x642 on the way). My strut is flush with top of bracket and with 0 angle. When I moved my packs up I got less bounce but front was not overly wet and still had good speed (for a stock prop).
                          Stringfly <>+++++ SEE VIDEO...
                          • blackcat26
                            High Speed Junkie
                            • Sep 2009
                            • 1598
                            #238
                            As long as you get the strut angle neutral you will have no problem with blowovers. I have only run mine in chop when in stock form and it did fine. Your COG or balance point needs to be somewhere about 9" from the very back vertical edge of the boat (where the rudder bracket is bolted on). This has worked well for me and I am still tweaking it in. My strut is about 1/8" above the bracket. I would not go by the bracket to judge the struts attitude either. Stand back and look at the edge of the ride pad and make the strut follow that same line. Seemed much more stable after I did that.
                            • blackcat26
                              High Speed Junkie
                              • Sep 2009
                              • 1598
                              #239
                              Originally posted by stringfly View Post
                              blackcat 26,
                              Stringfly <>+++++
                              http://www.youtube.com/watch?v=3f6lE-O74OA
                              As long as your batteries are fairly secure that should have cleared up most of the bounce. I bet you have a little positive angle on the prop. Again dont go by the strut bracket to determine the prop angle. I lined mine up by eye parallel with the back ride pads. Kinda non-scientific but worked better than eye-balling the bracket. Hope that helps.
                              • stringfly
                                • 88
                                #240
                                thanks....
                                Ok blackcat26, will check that angle some more. Thanks.
                                How was the video? ... a first ??? two Geicos together ???....
                                stringfly <>+++++
