Brushless ESC for 15" Catarmaran
  • Tom M
    • Apr 2008
    • 150
    I have a Proboat Mini C that I converted to brushless using an Ammo 28-45-2100. I was using the Mamba 25 esc but I have burned up 3 of them (THEY ARE NOT WATERPROOF AS CASTLE CREATIONS SAYS THEY ARE!!!!!) and now I am looking for an alternative. Please let me know which ESC you would recommend with my set-up. I run on 3s li-po.
  • screwball
    • Jul 2009
    • 464
    maybe this http://cgi.ebay.com/Team-Orion-Capta...5|293:1|294:50 and then just put a little bit of silicon on the ends where it isnt sealed
    James
    • Tom M
      • Apr 2008
      • 150
      Thanks James for the link, I forgot to mention, I've fried 1 of those also. I have not had good luck with speed controllers in this boat. LOL.
      • screwball
        • Jul 2009
        • 464
        hahaha that sucks maybe pick up a mystery esc and coat it with corrosion x spray then re shrink it and seal the ends
        • Simon.O.
          • Oct 2007
          • 1521
          That would be my suggestion too but with less emphasis on the waterproofing.
          Let me get this right. You have killed 4 esc's due to water damage and you are looking for another.
          I would suggest that you sort out the water ingress issue first before trying to get a water proof esc. If my boats come in with more than a teaspoon of water in them they are on the bench untill the cause is found and fixed.
          This includes boats that have flipped and waited up to 1/2 an hour for retrieval.
          • Tom M
            • Apr 2008
            • 150
            Well I have gone over and re-sealed the whole boat. The only reason why water got inside was because I flipped it and the tape on the hatch came off (was all out of hatch tape, so I had to use electrical tape; lesson learned) so water was able to get inside.
            • Rumdog
              • 6453
              Go on ebay and get a seaking 35 amp watrproof and watercooled esc. They're really inexpensive and work great! These really are waterproof too!
              • lincpimp
                • Jul 2007
                • 252
                HC sell the little 35 amp waterproof unit as well. Might be cheaper with shipping to go thru ebay though... I think the HC unit is the same as the seaking anyway...
                I run a mamba 25 in my mhz gecko and so far it has done well, save for the switch which is rusting away... Still works... Might want to remove that before the next outing... Damn preventative maintenance!
                "These rocky mountains aren't very rocky!" "Yeah, that John Denver is full of S**t!"
                • video200
                  • 837
                  have this one in my mini C http://hobbycity.com/hobbycity/store...ies_35-40A_ESC
                  took off the shring wrapp and coverd the intire thing in epoxy never been any water ishues sinse.
