BL Mini-C w/2700KV ammo 11.1V Lipo
  • jfabcustom
    Speed addict!
    • 98
    Built this with parts from my Mini Rio project that I abandoned.
    Sixty percent of the time, It works, Everytime!
  • JimClark
    • 5902
    Ad some more pictures and specs that looks pretty interesting
    Jim
    Billy Graham
    • jfabcustom
      Speed addict!
      • 98
      The first picture is the plastic mount that I made for the speed control
      The speed control is for an SV27
      The motor is an Ammo 28-35-2700
      The battery is a 3S1500 Mah 25C pack
      The second picture is the hardware it's for the mini hydro from mini cat racing
      The prop is an Octura X430
      • jfabcustom
        Speed addict!
        • 98
        This is what happend today when the rudder hit some unkown object that is submerged in the local pond.
        • jfabcustom
          Speed addict!
          • 98
          I cut this hole so I could get to the crack from the inside
          • jfabcustom
            Speed addict!
            • 98
            Five Minute Epoxy to the rescue!!
            • jfabcustom
              Speed addict!
              • 98
              I used five minute epoxy on the crack. Once it set I decided to fill the rest of the hull with foam. I had already filled the bow.
              • jfabcustom
                Speed addict!
                • 98
                That's it for now. I'll try to get video once it runs again, provided it's longer than 40 seconds.
                • jfabcustom
                  Speed addict!
                  • 98
                  New Hull, New hardware
                  This is a new hull with a new inline strut/rudder bracket that I designed and scratched out on my Dad's Bridgeport Mill. The blue anodized parts are from Mini Cat Racing and the raw aluminum part is what I designed. The component layout inside the hull will be different this time as well to accomadate a much lower C/G. Hull is ready to be tub tested. If she doesn't leak I'll just need to make a longer rudder pushrod and she'll be ready to run.
                  • Meniscus
                    Refuse the box exists!
                    • 3222
                    Good looking build. I'm curious to find out what the transom weight is and how it sits in the water. Have you figured out where the COB is?
                    • jfabcustom
                      Speed addict!
                      • 98
                      Not yet I just finnished the tub test. No leaks! It didn't seem to weigh the transom much more than the previous setup. None of the internal components had been installed at that point(speed control, reciever, batt, ETC.) So it was hard to tell. I'll get a pic in the tub when she's all together. maybee tonight.
                      • jfabcustom
                        Speed addict!
                        • 98
                        Ok here are some pics. In the first two the hull is balanced at 4.5" from transom which is about 32% of the 14" Hull
                        Next is the layout inside the hull
                        and these two are how it sits in the water. it doesn't sit much lower in the rear than it did with the previous setup.
                        • jfabcustom
                          Speed addict!
                          • 98
                          Any thoughts/Comments?
                          • Meniscus
                            • 3222
                            I'd say try it and see how it runs!
                            Also, wash the bathtub LOL => you asked for thoughts/comments! Or put a mat down to cover it up next time J/K
                            Make sure you get a video of the maiden voyage! We're looking forward to seeing how she runs.
                            • jfabcustom
                              Speed addict!
                              • 98
                              Your right! I guess it is about time for a CLR treatment in the tub? LOL! The fact that I work with metal all day doesn't help the tub's situation either. I'll make sure to get a video next time I run the boat. I should be able to run it soon since the weather here just cleared up today. Although the pond may still be in pretty rough shape due to the storms we had. It's only knee deep and it fills with leaves and twigs sometimes.
