brushless mini cat?????????????help!!!!!!!!!!!!!!!!!!
  • reelredneck
    • Jun 2010
    • 7
    i have put a 370s 4400kv brush-less motor and a water cooled 20 amp esc with a 3s lipo in a mini c hull along with a spectrum receiver and new servo. The running gear is all the same except for the prop shaft witch is now threaded to take different props. I have tried three different props all about the same as the stock mini rio prop with different pitches i have even filed one down to half the original diameter and tried it all with the same result. the boat just flips no mater what. even when i try to be gentle with the throttle it just flips before it even gets on plane. with the moded prop i could just get it on plane but it still wanted to lean hard right and the cavitation was horrible. Anny prop or drive advice would be greatly appreciated.
    Thanks
  • forescott
    Hopelessly Addicted to RC
    • 2686
    Drop down to a 2s pack. Thats almost 50,000 rpm on 3s!!! Too much.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      Volts X Kv = max RPM
      Max RPM should be 25-35k
      You can use a piece of #128 K&S brass as a shim and use the Venom 32mm props. But with 4400kv, wow, 35000 RPM that's about 55mph or more in that little hull!
      I did a similar build on 2s with 2900kv motors and 32mm props. No room for GPS, but it was wicked fast!
      • reelredneck
        • Jun 2010
        • 7
        thanks for the answers, but my problem is it wont even get on plane without flipping.i have tried just slowly working it up but it still flips. The one time i did just hit it it flew out of the water about 4 feet spinning around, busted both universals, and striped the servo gears. I don't have any 2s laying around so i will just bring my throttle rate way down on the tx for now. Also if i put a regular mini strut and rudder on like diegoboy did on his, will this help at all with the rolling problem?
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          Where is the COG? It should be about 27-30%
          But , if the power delivery isn't smooth, it's going to over power that little hull and flip. Should be running at about half that RPM. JMO
          • reelredneck
            • Jun 2010
            • 7
            my cog is 5 inches forward from the transom on the 14 in hull and the lipo is on the far left side of the hull to compensate.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              Might try moving it back to 4".
              You might try taking a vid of the behavior, it will tell us more than a description.
              • reelredneck
                • Jun 2010
                • 7
                OK thanks I'll try moving it back a bit and I'm headed to the lake right now. I'll try to get a good video.
                • reelredneck
                  • Jun 2010
                  • 7
                  Thank you, fightercat you have been a great help. I put a new octura red 30 mm prop on it and took my throttle limit down to 60% with 25% expo. I took the cog back as far as i could to 4.5 in from the transom and it runs much better.
                  At 60% throttle(max for now ) it still tilts right and wanders to the right but it is still bearable i just have to do a little compensating. The only problem is it is still plowing. The hull is running way to wet(3/4 of the hull in the water).I am going to ad a few nylon spacers to the prop shaft between the universal and the out drive and ad a shim between the hull and the drive to angle the prop up a bit more.Hopefully this will get it to ride right. If not ill try to ad some weight in the transom area.
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3480
                    Move the COG back to 4" and it should help stop the plowing.
                    Cool, glad it helped. =)
                    • forescott
                      • 2686
                      Be careful. Running that esc at 60% throttle is transferring that other 40% into heat in the speed control. It could cause the esc to burn up.
                      • bbosncali
                        • 756
                        I'm running a mongoose 8.5 6000kv sensored with a 40mm prop. On 2s it won't flip on 3 if I'm gentle out of the whole its pretty good but way too much power for that little boat
                        miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
