skipping along
  • bigbearillinois
    • Jul 2009
    • 11
    skipping along
    My Mini C seems to skip or bounce along...what kind I do to make it run smooth?
    Conditions -All original set up - water is like glass
    I'm not familiar with the Mini-C, but most skipping with cats is caused by the prop being run too deep. Raise the prop 1/16" to 1/8" keeping the same angle. Do this by setting the cat on a flat table and neasuring the distance from the bottom of the strut and the tabletop.
    Other causes can be too little weight for the power/speed - add a few ounces of kead at the CG and try again. Finally, over-powering the hull design can cause skipping and hopping. These are general causes that may or may not apply to your boat.
    • egneg
      • 4759
      Adjust the steerable drive so the top is flush with the lip where the deck joins the hull.
      IMPBA 20481S D-12
      • bigbearillinois
        • Jul 2009
        • 11
        thanks guys - I will try adjusting the drive up - i cant get out until later to try it.
