Blackjack 29 V3 .187 upgrade shaft
  • Rayzor31
    • Sep 2016
    • 2
    I purchased the upgrade strut and the .187 upgrade flex shaft for my blackjack 29 v3, can I use the 9/32 brass tubing with the .187 Teflon liner or do i have to use the 1/4 tubing without the liner? Is there enough material to mill the strut or tubing for fitment of the 9/32?
    • 4338
    for a 3/16" (.187) flexshaft use 9/32" tube w/ .187 liner or 1/4" tube w/o liner. Seems like a lot of work to replace the 1/4" tube already in the hull. I would just pull the teflon liner and run the .187 OSE shaft that way. Looking at the strut on my V3, the nose cone tapers down from 11/32" OD to just a hair over 1/4", so you could probably modify the strut if you felt inclined to go the difficult road.
    • Rayzor31
      • Sep 2016
      • 2
      The bare shaft on brass tube won't produce too much heat to cause a shaft failure?
      • Mxkid261
        • Jun 2015
        • 734
        Not if the cable is well greased every run and the motor is aligned perfectly with the stuffing tube. I have 5 boats they all run 3/16 cables with no liners
        • Blevins
          • Feb 2014
          • 20
          Just remove the Teflon liner and run the 3/16th/.187 shaft on the stock tube. Been doing this for over a year at speeds of nearly 80mph on GPS....
          BlackJack-Miss Geico 29 V3 Leopard 4074 2200KV 78mph on GPS so far- FE Fun boat
          JAE 21GT B Hydro outrigger, Whiplash B Sport Hydro-Nitro Race Boats District-14
          www.ABMods.com
          • Fixitguy1
            • Nov 2016
            • 45
            what prop are you using looks crazy fast and stable
