What have you done to your " BLACKJACK 29" lately?
  • waterproof
    • Jul 2013
    • 239
    #31
    Originally posted by Leadfingers View Post
    I drilled out the rudder inlets and the outlet on top to make them larger, along with a larger water lines and the splitter, not sure about pressure but it did increase the volume of water. I like having the water coming out on both sides of the boat, easer to see. I am going to try the stock connectors first and see how they do, upgrade later if need be.
    Ok, Sounds like a great upgrade!
    How is your strut adjusted?
    I maby think that the boat would use less amp if it in stock posission?
    Stock was the top of the strut plate goes in the same line as the top of the rudder mount..
    Have read about that now, and my first stock run on 6s gave me good temp, but i saw it looks like it run to wet or have the strut to long negative since anyone says theas 29 proboat cat like the strut to be about 1-2mm over the rear of the sponsons..
    • Mxkid261
      • Jun 2015
      • 734
      #32
      The caps are just too small on it mine got pretty hot a couple times before they went.
      • Mxkid261
        • Jun 2015
        • 734
        #33
        Put it this way I regret not just ponying up and getting the swordfish pro+ right away Lol
        • waterproof
          • Jul 2013
          • 239
          #34
          Today i tried 6s and im happy with the temp! But i think it should run a bit faster.
          I took the strut back to the stock posission, also lower it a bit vs have the strut flat on a table with the sponsons.
          Its about 1/8" or 3mm lower than when its flat with the rear sponsons and sure this help a lot to the motor connectors.
          This was the issue and the stock timing on 15, the boat runs cooler on 6s vs 5s with higher strut!
          Always run 7.5 timing.
          Temp on 6s after 3 min:
          Motor cable 55c
          Esc 55c
          Esc capitors 50c
          Lipo 28c
          Motor 40c
          Battery connectors 47c
          After this 3 minutes i run it again for 4 minutes:
          Motor connectors 55-60c
          Esc capitors 52
          Esc 50-55c
          Lipo 38c
          My thought is that the small upgrade as changing the directions of cooling lines, timing 7.5 and stock strut posission make it mutch safer to run on 6s, but i see that it could run faster, if i raise the strut from stock the heat will come.
          Any tip to make it run light and easy without raising the strut from stock?
          Lipo 5200 3s was almost at rear but i could put them littlebit longer back.
          • Leadfingers
            • May 2015
            • 46
            #35
            Sounds good, waterproof.....we will get it figured out sooner or later. I tried to run mine yesterday with the strut set back to factory settings and stripped the collet, I had the updated flex shaft, but new Aeromarine collet I got was to long and I can't use it without moving the motor back or cutting off the stuffing tube and flex shaft and I'm not sure about doing either.....................any advice? I tried to order the short collet, but they are out of stock at OSE.
            Interesting thread below on the water pressure/flow thing. I learn something new everyday about this hobby, that's what makes it fun and interesting.......anyway I'm down and out until I can fix the flex connector.
            Mxkid, thanks for the info on the cap banks......looking forward to seeing your new build complete, good job!
            • waterproof
              • Jul 2013
              • 239
              #36
              You could try to cut the shaft or get someone to do it for you.
              Can you use the stock flex system?
              I have run it 4 more times and it still work, but the yellow motor connectors was little hot the last time.
              Have used it 8 times total on 6s now.
              Just wait for my stock balanced and sharpen prop arrive from rcchiefhobbies.
              Looking forward to see how it goes with your boat with 180A esc and stock motor.
              Sure it works now, but i want to adjust the strut in every posission and not get very hot connectors.
              I also change out the cooling lines the same time as i set the strut to stock posission, but the cooling line change dosnt help so mutch on the connectors?
              Could just raise the strut and try again but im affraid to burn something, have you check the temps after you set the strut back to stock posission vs raising it a bit?
              What is your experience with the battery posissions on stock strut posission?
              The 5200mh 3s all way back and it runs fast, but its bump a bit. Not very mutch and it have never blow over yet. Want littlebit less bumping before im happy and its not easy to eliminate it.
              • Leadfingers
                • May 2015
                • 46
                #37
                When I did the waterline upgrade, I used the small ID tubing on the exit lines from the motor and ecs, so it would keep some pressure on them, but you are right not much help, heat wise, with the connectors. I guess the stock electronics are going to run HOT 185F +if you keep them.
                If I shorten the tube, I would have to shorten the flex shaft also. just not sure if this is a good move or not, in order to use the larger collet..............anyway the BJ is down for now, hope to get her up and going again next week.
                Just keep playing with the battery placement, you will find a happy spot......good luck with the new props, keep us posted.
                • waterproof
                  • Jul 2013
                  • 239
                  #38
                  Yes sure :-)
                  Many buy a raw flex and cut it to the lenght they want, i dont know how you could do it.
                  But if you get the parts soon its more easy to just wait :)
                  What type of lipo do you use? I maby want to change mine out for some dinogy 65-120C, just to see if it get more power.
                  The speed is ok, i dont have gps but its around 45-50mph i think, on the YouTube videos it not looks like mine is slower than 45-50, would be nice to have a gps.
                  If the 180A esc keep it colder i will order it, are you going to upgrade the seaking v3? Or would it be fine stock from offshoreelectrics?
                  What do you think about fan cooling on a rc boat?
                  Could use a castle motor fan on the wires or esc, easy to plug it in to the rx, but i have never seen that before on a boat. This is just an idea and maby someone in here know more about that will help or not.
                  Tfl hobby also have cooling plate for esc, could mount the wires around the cooling plate maby.
                  Would have been nice with two water pickup but i dont want to drill a hole in the hull.
                  • Brewbud
                    • Aug 2014
                    • 117
                    #39
                    For those of you with hot connectors -what connectors are you using? The stock connectors do get hot. It is just a function of physics. High current with resistance = high temp. You could try switching out to 6mm or larger bullets. They have less resistance so will run a little cooler. In turn it will help the whole system.
                    Edit: Just realized this is v3. What are stock batt connectors on v3?
                    Knowledge is knowing a tomato is a fruit. Wisdom is knowing not to use it in a fruit salad.
                    PB BlackJack 29 / AQ Motley Crew / Tenshock Mini ECO / Phil Thomas Stealth
                    • waterproof
                      • Jul 2013
                      • 239
                      #40
                      Stock battery connectors is ec5.
                      They work fine for me without getting to hot.
                      I dont know if it worth the job to change out 6 connectors to 6 since it just littlebit bigger than stock.
                      Would maby help a bit but the version 2 had almost the halv of size and they also get the same hot temprature.
                      I have run it many times now on 6s after i set the strut to stock posission and that helps on the connectors.
                      Now i have take a empty coolingline around them so they dont hit the roof inside the hull and so they not are too close so they get alone, think that also help so they dont lead the temp or collecting temp.
                      • waterproof
                        • Jul 2013
                        • 239
                        #41
                        I got help from Chief in here to sharpen and balance a new stock prop, thank you Chief :-) Very happy for your help.
                        The prop arrived just after one week, i must say wow what a difference!!
                        It almost run smooth even i had the batteries all way back, before i must have them almost at the front to not get it to bounce very fast, i think it give more torque, and maby 3-4 more mph.
                        It is a must to give your stock prop a good work! It was very different to drive it vs a stock prop out of the box.
                        Now it jumps more perfect and i like the way it handles.
                        Im still run 6s for around 6 minutes with mixed trottle.
                        The esc got a few less degrees after i got the new prop, but the water was also little colder.
                        Motor connectors is around 55-60c but the black one reach 80c on todays run.
                        Maby going to order a seaking 180A but om not sure.
                        Have you got your new esc yet leadfingers?
                        Could also get a 1500kv proboat motor.
                        Anyone that know how the speed would be with v2 1500kv vs stock 2000kv motor?
                        It do works today but i like to be more safe..
                        • Gopherboy6956
                          • 40
                          #42
                          Hey Guys - Sorry to jump in to this thread - But I wanted to see where the best place to sell my Blackjack 29 might be? I have a MG29 and a Shockwave, and I just don't need three boats. Any help or pointers would be awesome. I looked in the FE main list and didn't see and FS/WTB threads.
                          Thanks!
                          • Gopherboy6956
                            • 40
                            #43
                            Thanks!
                            Sorry - I eventually figured it out! - http://forums.offshoreelectrics.com/...ck-29-for-sale
                            • Pedro Ramos
                              • Nov 2014
                              • 144
                              #44
                              i used to run my bj3 on 6s all the time, never had a problem, I just lower the timing on the motor and do not run the batteries to death, I believes that is the problem with all you folks, set a timer on your radio or your cell for around 8 minutes and problem gone.
                              • waterproof
                                • Jul 2013
                                • 239
                                #45
                                Yes, timing on 7.5 helps on everything.
                                What timing do you use?
                                I got 77kph/47,8mph on a gps today, was a bit Wind and not flat water.
                                Hope to reach 80kph next time.
                                This speeds is with this setup:
                                Strut in stock posission
                                Timing 7.5
                                Sharpen and balance stock prop from Chief in here (it is a must and give you a few mph and mutch better handling)
                                5000mh 3s 35c lipo almost at rear in the battery tray, could only get a finger between the battery and rear of the tray.
                                Water temp was only 14.5C and everything runs cold, low temp even on the motor connectors.
                                Is it other here that have a gps and could tell the setup on the boat? :)
