Guys, this boat is really amazing and super stable. Had a chance to get a good deal on the v2 of this boat but opted for the v3 and really glad I did. The new hull design is super strong and well built. The fiberglass is def legit and doesn't feel weak by any means. I started with 2 2s lipos 5200 mah 30c and the boat was fun but rather tame in a flat pond. Was fun the first few times but decided to invest in 2 3s lipos 5000mah 50c and give it a try. What a difference! I also just upgraded my prop to an Octura m440 sharpened and balanced. Just an amazing step up from the stock prop which was already decent. The Octura kicks up a sweet tail and I clocked it this afternoon at 58.6mph! 2000kv motor and 120 amp ESC slightly warm but not hot at all. Great job Proboat, this is a really funny boat to race!
Proboat Blackjack 29 v3
I just got a bj v3 as my first boat, and I couldn't get that porpoise out to save my life! multiple strut and COG adjustments. went through an entire roll of electrical tape in a few hrs.
sharpened and balanced a x642, and it was a different boat! However I think a 642 is to much for my setup, it was incredible the difference in the short time I ran it. im working on a x440 now.
Awesome! Ya my M440 S&B made a difference over the stock prop. Maybe a tad less acceleration but top speed def picked up (like a rocket on 6s) and it's super smooth. Motor and Esc were warm but not hot. If you experience anything else please share, thanks!Originally posted by Ryanrodfl6363lu View PostI just got a bj v3 as my first boat, and I couldn't get that porpoise out to save my life! multiple strut and COG adjustments. went through an entire roll of electrical tape in a few hrs.
Is be curious as to what a x640 would do. X642 seemed like I couldn't get the rpm I wanted so be careful w it.
Luv2fly- where are you setting your strut? It seemed like w my factory prop I had to run the strut about 1mm above the hull and -1degree down just to keep proposing minimal. But with that setup holeshot was terrible and it would cavitate bad until the boat planed. Even in a moderate turn the prop would slip.
The x642 was awesome w identicle strut setting. Holeshot, turning, stability. Very little cavitation if any.
I haven't made any changes to the strut. All still in their factory set positions. I'd be open to ideas though if you guys think a change might help. Sorry I'm just getting into this so still learning.Originally posted by Ryanrodfl6363lu View PostIs be curious as to what a x640 would do. X642 seemed like I couldn't get the rpm I wanted so be careful w it.
There's a strut mod thread on a thread here. It helped me drastically. You file out the top 1/3 of the strut slot so you can raise the strut and also achieve a neutral to slightly negative prop angle. I have my strut a hair above the bottom of the hull if I set the boat on a level surface w less then 1 degree of negative angle. This is my first go round too so I'm sure a vet will correct me or add insight. But it helped me heaps!
