Blackjack or Geico 29 on 45, 2P
  • skeeler
    • Jul 2007
    • 208
    Is anyone running the Blackjack or Miss Geico 29 with a 4S battery in each sponson for a 4S, 2P setup with a total of around 10 to 11 amp-hrs of capacity? If so, what motor are you using? What prop do you find works best?
    Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
    '09 Miata.
    Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
    I do, 4s2p, 10,000mah. I run Leopard 2200kv / 4082 with m445 and/or x642…
    Currently I have a Leopard 4074/2000kv, m445.
    Getting a 4s battery into the sponson is PITA. Lol....
    Sent from my Droid using Tapatalk 2
    • skeeler
      • Jul 2007
      • 208
      Thanks for your reply. Did you add additional bracing to support the larger, 4074 motor? Have any pics?
      '09 Miata.
        Well sir, I have...but...my main computer died a week ago and I have nothing left , still waiting for the new computer and I am praying that my back up works. Mean while I am struggling with another computer with Windows 8.1, ( I can't tell you how much I hate it, would rather go back to Windows Vista ) I will see what I can do, may be I will take a new pic. Essentially I used this :http://www.offshoreelectrics.com/pro...prod=ose-83005 for the rear support. At first I made a nice wooden one but it fell out during a flip over. With this I made nice rails around the trangle legs so lots of Epoxy could be poured in to the little "dam".
          I run a pair of Zippy 4S-40C 3000's in each sponson. I only run an AQ 1800kv motor on a M445 for 4 minute offshore races and M545 for 6 lap sprints. Runs very nicely.
            Tell me about it , I had wanted to practice for some driving skills, my brand new AQ 1800kv with a M445 burned in 45 seconds. ( it was nice while it lasted, ) Only thing that I can imagine was my over zealous soldering of the 5.5mm bullets might have over heated the insulation at the rear of the end bell...
            Don't mean to drift away from the topic, but I will try to get another and run it.
              Here are some shots, pardon the quality.
              • skeeler
                • Jul 2007
                • 208
                Thanks to both of you.
                '09 Miata.
                • skeeler
                  • Jul 2007
                  • 208
                  By the way, if running 4S, 2P and the AQ 1800 motor, do you think it's necessary to reinforce the hull? If so, how would you suggest doing so?
                  '09 Miata.
                    Actually I have modded out my Geico. I got rid of all the wood and installed a different motor mount from OSE. I actually have to tear out the stuffing tube and put in a new one since the mod I did left too much space between coupler and stuffing tube. I noticed after running this weekend that the flex cable is bent and can't be repaired. It could be cut shorter and used for some other project.
                    I added a layer of Carbon fiber from rear to about 2/3 the length of the hull. Lets see if I still have pics in here...
                    The motor mount I've changed again to a $8.00 OSE mount and a HiFei 120 esc...
                    • skeeler
                      • Jul 2007
                      • 208
                      How did you remove the wood?
                      '09 Miata.
                        Some snaps out in a pinch, others you have to be careful and slowly work them loose by wiggling them. Take your time, don't rush.
                          Ray, this is one of the BEST reinforcements I have seen, congrats !
                          I lack such skills and collateral damage is my middle name, so I humbly left the factury wood platform intact.
                            After the wood is gone, sand well, clean well with a solvent before gluing in anything.
                            • skeeler
                              • Jul 2007
                              • 208
                              Ray, thanks for the guidance. Is there any trick to pulling out the battery trays, or are the the same as the wood? Can you get them out without removing the wood?
                              '09 Miata.
