Miss geico 29 v2 not 6s conpatible? How could it run in 50mph?
  • BHChieftain
    Fast Electric Addict
    • 2051
    Originally posted by waterproof View Post
    You always give good answers! :)
    I have looked at the proboat blackjack 29 on youtube, is this the same boat as Geico but the blackjack have the same esc and motor like impulse 31 v2?
    It looks like a rocket, so maby later i could change out the esc to the 80 amp from proboat an run it on 5-6s.
    Miss Geico and blackjack is 100% like exept the esc and motor? or have it bigger flex?
    Im impressed of the accsleration and top speed of the proboat cat hulls With 5-6s battery setup:D
    Hi, The MIss G and the Blackjack have the same hulls, different color. Blackjack has a higher kv motor and higher amp esc (80amp, and it is rated to 6s VOLTAGE, but you've seen my other posts about reliability on running 6S on an 80A esc), and also has offset rudder. Comes with a metal prop. Rest of the boat is identical, including the flex drive.
    Chief
