Will a proboat miss geico flex cable work for a blackjack 29?
  • 96motorhead
    • Apr 2013
    • 38
    just wondering if this cable will work because the blackjack 29 flex cables are on back order until next month.
    http://www.ebay.com/itm/NEW-ProBoat-...item27cdd2067e
    OSE sells top notch upgrade cables, I have MG V1, I don't know if it's the exact same length, but you can measure the one you have now and determine: http://www.offshoreelectrics.com/pro...e-mystic-cable
    • 96motorhead
      • Apr 2013
      • 38
      I snapped mine in half in the middle of the pond so I'm not sure how long.
        I see, well, my feeling is that they should be the same length, but hopefully someone else who is SURE of the measurement will chime in to help, good luck!
        In any case, I don't know which maker is the one on e Bay, but I can tell you for a few dollars more, the OSE ones are the best!
        • Megabiker98
          • Jan 2013
          • 253
          I got a miss geico one from kintecracing for my mystic, fits just fine!i would assume all the of these boats r the exact same thing!
          • 96motorhead
            • Apr 2013
            • 38
            Does anyone know the length of each?
            • champion221elite
              • Jul 2013
              • 216
              Just buy a Hughey .150" flkex shaft with a 3/16" stub and cut it to length. Youll have a much higher quality shaft, and its easy to do. Just remember to measure twice before you cut.
              A stock BJ 29 flex shaft is 12.75" long from the tip to the threads on the stub. The stub has a length of 2-7/8"
              • Megabiker98
                • Jan 2013
                • 253
                Nope, I just know that it fits so I'm using it! :P
                • 96motorhead
                  • Apr 2013
                  • 38
                  I think i'm just gonna get the MG29 flex cable off ebay. Seems like it will work.
                  • 96motorhead
                    • Apr 2013
                    • 38
                    Also I bought a new proboat prop since my other one is long gone. Do I need to balance it?
                      YES!!! The PB prop is made of steel, although they say it can be used, don't use it w/o balancing . It is heavy( steel) and any unbalance character will be amplified under high RPM thus wearing out your components quickly, especially the bushing in your strut!
                      • Megabiker98
                        • Jan 2013
                        • 253
                        You should have just gotten an octura, would have gotten u better performance and lighter material! :/
                        As to ur question, I agree with tlaunder, u should definently balance it!!!
                        • BHChieftain
                          Fast Electric Addict
                          • 2051
                          The Miss Geico and the Blackjack use the same stock cable.
                          Chief
                          • SloHD
                            Slow Electric Addict!
                            • Apr 2013
                            • 337
                            I would get a kintec or ose shaft. Much better quality. They are all the same size.
                            • 96motorhead
                              • Apr 2013
                              • 38
                              What balance stand is recommended and does anybody have any tips on balancing the prop?
