HI Alan,
I understand your desire to upgrade and stay with 6s since that is what you already have. Keep in mind that the 4082/2000KV is really a 4s motor, I have a 4082/2200kv with a m445 prop and this motor is an amp hog, so I run 4s2p, with the parallel set up I have 10,000 mah and I get good run time. Yes, I can get over 6 or 7 min. continuous run time, but I always NEVER do that because of heat build up. After 2 min. I bring the boat back and check temp, then go out again. The heat build up can damage your gear, as heat builds up, the likelihood of failure grows disproportionally, and that is just talking about my set up with 4s.
If you have not bought your motor yet, I would look into the something in the 1600kv range . Are you using 6s2p? I doubt it will fit in the boat, if you plan to use two 3s, there will not be as much run time as you hope.
Also keep in mind that part throttle is HARDER on the equipment than running full throttle, I am not a nitro guy but may be in the nitro world is different. The part throttle makes the ESC work Much harder and heat builds up much quicker. So if you think in order to keep the amp draw manageable all one has to do is use part throttle, it does not work that way in reality. If you want 6s set up, get a set up so you can run full throttle all day long.
