bj hull
  • motohead417
    • 92
    bj hull
    hey guys, does anyone know wer i can buy a bare bj hull? i damaged my hull and im looking for a replacement.
  • macz
    • Jan 2009
    • 118
    eBay
    • mtk
      • Jun 2009
      • 58
      Do you have pictures of the damage. I did alot of damage to my boat this week . I cracked the front of my bj all the way sponson to sponson and alot of cracks but I fixed it with some fiberglass and marine grade epoxy it was caused by a reciver failing and my boat going into a dock and It wasn't the stock radio system
      • motohead417
        • 92
        can you post some picks of your repairs. hear is a pic of the damage.
        • mtk
          • Jun 2009
          • 58
          My boat is shiping from Maine cause I was out of state and I shiped it. Is your crack all the way
          • motohead417
            • 92
            yea it goes all the way through.
            • mtk
              • Jun 2009
              • 58
              Ok well it will be easy then first you need epoxy and some fiberglass I personly would pick a fiberglass mat. also some fiberglass hardener I got all my stuff at home depot first I would use some epoxy to coat the crack lightly. Then I would wait till it dries. I would then cut some fiberglass a bit bigger then the crack. Then mix the epoxy and the fiberglass hardener in a small container the a bit bigger the fiberglass you cut. cover the fiberglass you cut in the mixture at this point you need gloves I would put the fiberglass you cut on the inside your hull then let it dry. If you want extra protection then do the same on the outside
              • motohead417
                • 92
                Should I remove the 2 pices of balsa that run along the inside? Cause the crack is right behind those 2 pieces of wood.
                • motohead417
                  • 92
                  • mtk
                    • Jun 2009
                    • 58
                    Are you talking about the battery trays
                    • motohead417
                      • 92
                      no the 2 pices that run along the seam wer the top and bottom if the hull are joined together
                      • mtk
                        • Jun 2009
                        • 58
                        Yes remove them but only remove what you have to
