help
  • mtk
    • Jun 2009
    • 58
    help
    the collet nut on my blackjack is slipping it is as tight as it goes what should I do
  • Christaphason
    • Jun 2009
    • 107
    is the set screw on the flat part of the shaft?
    • mtk
      • Jun 2009
      • 58
      yes it is
      • Chewy6696
        • Apr 2009
        • 14
        From your hoppy shop get a piece of brass sheeting. Cut out a little piece and wrap around the tip of your drive shaft and re-tighten the collet over the brass piece.
        • animigan
          • Jun 2009
          • 71
          There was an earlier thread called "help with wimpy collet nut" that might be helpful for you...it was for me.
          • animigan
            • Jun 2009
            • 71
            Also, I was wondering if this ugrade from Kintec Racing might be helpful. Perhaps some of the senior members can comment on whether or not this would be a good choice. Go to this website and scroll down a bit.
            "3 PC Flex Collets The strongest best made on the market. Precision cnc made from 303 stainless steel with a brass insert. Makes for a slip proof secure grip. Inserts sold seperatly should you ever wear one out. 5mm, 8mm, x .150, .187 Made in USA"
            Andre
            • Christaphason
              • Jun 2009
              • 107
              That collet seems pretty good, it is the same technology used in pneumatic die grinders, so i would think that collet would work
              • mtk
                • Jun 2009
                • 58
                after all that I figured out that the collet screw came off I used some locktite and it is sealed thank for the help
