Exploding Capacitor
  • krusty
    • Jul 2008
    • 39
    Exploding Capacitor
    The first capacitor that I blew up was on my Hydra 240 I did however manage to make it pass at 48.3 mph. I then of course had to restore my boat back to stock I was running it today and blew up another capacitor on the stock ESC. I did manage to pass at 39.7 mph which I would be happy with had I not exploded another capacitor. As the picture shows I am physically blowing the outer case off of the capacitor and the internals are smeared inside my boat hull. I did check the temperatures on the ESC it was 95°F as well as the motor was around the same temperature, so I don't think it's a temperature issue. Someone had told me that the reason the capacitor blows is because the batteries unable to supply adequate current, I am running Maxx amps 8400 milliamp 35C 7.4 v x 2 I should not have a battery supply problem. I can tell I'm going to get good at changing capacitors on my Hydra 240. Any help would greatly be appreciated Krusty[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
  • domwilson
    • 4411
    Try shortening the ESC and/or battery leads. Capacitors will explode if there is too much ripple current. Does your driveline spin freely?
    Government Moto:
    • krusty
      • Jul 2008
      • 39
      I will shorten the batt. leads, this will help with the ripple curent? I spun the drive line by hand and it is smooth.
      • domwilson
        • 4411
        As more current flows thru a resistance, in this case, wire. The higher the voltage drop. Capacitors try to fill this voltage drop. Especially under heavy loads.
        By the way, Nice paint job.
        Government Moto:
        • krusty
          • Jul 2008
          • 39
          Thanks for the tip and the compliment on the paint had it done this year. On my mod set up with the hydra 240 I will cut 3" off the batt leds and I can shorten the leads to the motor by 2" and see what happens. I don't think I can get the stock esc apart to replace the capacitor but the hydra will be easy. Thanks again krusty
          • domwilson
            • 4411
            It's dremel time!
            Government Moto:
            • 6S HYDRO
              • 1325
              Ill buy that esc for 20 bucks
