fuller's hardware
  • mtk
    • Jun 2009
    • 58
    fuller's hardware
    I am thinking about the cat hardware what do I need exactly what also the the collet nut goes to the flex drive and then what does that connect to in the fullers also I have a grimmracer prop
  • Christaphason
    • Jun 2009
    • 107
    When i purchased the Fuller's Cat Hardware, All i had to do was drill 2 holes, you can use the original top holes where the outdrive mounts.
    My hardware came with a flex shaft with propshaft and drivedog already preinstalled. All you should have to do is cut down the flex cable to the appropriate length.
    My flex shaft fit into the stock coupler on the motor, i recommend adding a bit of solder to the end of the flex shaft after cutting it to the appropriate length. Remember to leave a slight gap about 1/8'' between the drive dog and strut.This flex shaft even came with a prop nut.
    You will need some servo pushrod and a linkage to adapt to the horn on the rudder and you.
    hope i helped
    --Chris
    • mtk
      • Jun 2009
      • 58
      where did you get it how much
      • Christaphason
        • Jun 2009
        • 107
        This is the fullers website
        They also have an ebay store, here is the hardware your looking for.
        http://cgi.ebay.com/Fullers-MONO-Boa...3%3A1|294%3A30
        EDIT:Be sure to note when you order that if you want a 3/16ths shaft to tell the guys at fullers you would like a .150 flex cable
        • mtk
          • Jun 2009
          • 58
          thanks so much last thing how did you make the steering work
