overkill!!!
  • motohead417
    • 92
    overkill!!!
    what motor and esc package would be overkill for the blackjack?
  • RCprince
    • Jul 2007
    • 1684
    Why would you wanna know about overkill? why not ask which is optimal.
    Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
    • nate
      • 1702
      HAHA, Overkill is the Blackjack when you recieve it right out of the box...
      Get rid of the outdrive system, get ya a nice speedmaster strut and rudder, then swap to an Ammo 2300 or so, should be about all that hulls good for.
      LMT
      LehnerMotorenTechnik.com
      • bigpapa
        • Apr 2009
        • 2531
        nate nate nate u da man lol
        THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
        CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
        • motohead417
          • 92
          wow why the hostility.... nvm
          • z400
            • 1333
            No hostility in this thread.
            What im reading is the exact truth.
            The Blackjack hull just can not go as fast as youd like it to.
            Well it can, but i guarantee you that you will not like it.
            Z
            KBB34" Mono - Fast
            ToySport Triton- Not as fast
            • domwilson
              • 4411
              There was a guy on here named Obrien and a few others who went over 50 mph in theirs, using a Ammo 2300, and a detounged X642. They seemed to like it. It's just a matter of spending some time and tweaking (Not the meth kind) to get it going the way you want.
              Government Moto:
              • nate
                • 1702
                Z400 is right, no harm done, but I was just stating that the outdrive is garbage, I tried doing some mods and found out that I should have taken the money and fixed the poor handling instead of trying to pass 45mph...
                LMT
                • domwilson
                  • 4411
                  I agree. The outdrive is garbage. Mine broke when trying to remove it. You just have to compromise between speed and handling. If you want better handling, go with a wider hull like a MM or a skunkworks.
                  Government Moto:
                  • nate
                    • 1702
                    Hope this helps, heres my two bj26's.. do this! haha
                    LMT
                    • nate
                      • 1702
                      Correct, and think on this a min, the strut adjustments will allow you to work on different ride height for better speeds with a wider range of props...
                      LMT
                      • domwilson
                        • 4411
                        (In a deep voice)Yea!
                        Government Moto:
                        • TCR
                          • 139
                          What models are those rudders/struts? TIA
                          Tom
                          • bigpapa
                            • Apr 2009
                            • 2531
                            looks like speedmaster
