Hey need help?
  • jlr3rd1
    • 240
    Hey need help?
    hi this winter i pulled the flex shaft and greased it and re installed the unit,now when i run the boat it shuts down @ f. t. ??acts like low batts , but they are fully charged. i am run n a pair of dtx 3800 6 cell and electrifly 3600 7 cells:) used them today in my supervee and runs fine. any one have any ideals?? I DONT KNOW
    2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
  • domwilson
    • 4405
    Do you have the programmer? Set the ESC for Nimh and reduce the LVC.
    Government Moto:
    • jlr3rd1
      • 240
      no i dont have?? but the boat ran fine last year? can the esc change??
      • domwilson
        • 4405
        Some on this board have reported that they sometimes lose their settings. There is a workaround in the blackjack section until or if you get a programmer.
        Government Moto:
        • jlr3rd1
          • 240
          bum r how much does those cost? sorry but still learn n.
          • domwilson
            • 4405
            Take a look at this link...http://forums.offshoreelectrics.com/...ead.php?t=3549
            Government Moto:
            • jlr3rd1
              • 240
              AWESOME :) THKS SO MUCH!! i will try tomorrow!!!
              • jlr3rd1
                • 240
                well after reset n the esc?the same thing, the boat still shuts off @ ft??? i noticed that after the boat arm s ,then i also hear 5 double beeps?? if the boat is not all the way in the water it will go to ft, but boat all the way in the water it shuts off @ ht???could this have anything to do cause i removed the drive flex shaft?? STILL NEED N SOME HELP
                • domwilson
                  • 4405
                  You might want to invest in a programmer card. They are around $20.00 and are sold here...http://www.offshoreelectrics.com/pro...prb3311&cat=75
                  Government Moto:
                  • jlr3rd1
                    • 240
                    THKS is there much to installing the unit?? i am willing to try anything and the site showed 0 in stock???
                    • domwilson
                      • 4405
                      Then you may want to try here...http://www.horizonhobby.com/Products...ProdID=PRB3311
                      Government Moto:
                      • sn00p
                        • Jan 2009
                        • 72
                        i would check the prop spins freely with your hand. It sounds like you re-installed it without any tolerance and set it a little tight OR since the your batt packs ahve given up the ghost.
                        Try arming your boat with full throttle selected wait for beeps then let the throttle neutralise. Then try boat out.
                        • jlr3rd1
                          • 240
                          ok should the flex shaft have some play or not? boat ran fine until i greased the shaft??? i think it something i did boat ran fine before
                          • domwilson
                            • 4405
                            Make sure you have 3/16" to 1/4" clearance between the strut and drive dog. Also, what kind of grease did you use?
                            Government Moto:
                            • Meniscus
                              Refuse the box exists!
                              • 3222
                              I know that once mine acted a little strange with the stock radio system. Are you absolutely sure that no water got inside the radio box? and if water has gotten in, have you checked to see if the receiver is wet or damp due to condensation?
                              I would go through the suggestions above before entertaining my comments, but I did want to offer some of my experiences.
                              As a final thought, how were the batteries stored and did you cycle them at all? Also did you inspect them for any damage such as a swollen cell etc.?
