Get rid of those stupid Turn Fins!! i have Had no issues running with out them from day one. they are good to gain 10+kph.
New Power System For BJ 26....
I will get rid of turn fins for sure. I must run this boat few times to fix the tem problem and check the speed. Here is few more pictures. Thanks guys, good staff....
RobertDJI Drone Advanced Pilot
Canada
up Grades
Lipo power
I have done almost the identical up grades to my boats!
I f it stops raining here I will get a run in and let you know what the gps said. I my self am running an x-442 I found the x-642 a little big,but this just might be my boat.
Feigao 8xl
Hydra - 240
MaxsAmps 2 X 8400 35C 7.4 v
traxxsas water prof servo
Fuller's Hardware
angled & trimed & sharpened the turn fins
Speed
Lipo Power
It ran 47.8 mph on the x442 and 48.3 mph on the x440 both balanced and sharpened. It did run hot and I pushed to hard on the last pass I blew one of the capcitors on the Hydra 240. So I am back to stock until my Hydra get's fixed then I am sure with some tweeking I can break 50 mph. I think that the x642 is to big at least my number are saying that![IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
Krusty, great pictures! I like when people upload many pictures. Words are ok but many times is just easier to see it. Thanks.
BDW, what is the model of your Garmin GPS that you are using?
Canada
Look at post #16 to see how his strut is adjusted. He broke 50 with his setup.
http://forums.offshoreelectrics.com/...ead.php?t=2200Government Moto:
yes you guys w/ the fullers kit need to push your struts all the way forward toward the transom, and also you need to put a piece of brass tubing in between the strut and the stock stuffing tube and then shink wrap over it, if you leave the flex unsupported for that length and you have your drivedog correct with gap, it can make the flex knot up and kink in that unsupported section. hence ruined flex and possible loss of prop
Last saturday my set up got me 38.9 mph on stock prop. I will try x642 on 2 x 3s 5000mAh 30C batteries next time and will increase timing from low to normal. Will post GPS next time. Thank you for help, wicked!
Canada
