BJ26 vids and pics lets see what you got !!
  • MAXAMUS
    • 210
    lets see your vids and pics so we can see whats out there, remember to list your set up with GPS speeds if poss
    my set up and link to video
    bj26
    fullers o/s cat hardware
    ETTI 150 amp esc
    2x 6600 mah 20c lipo
    futaba 2.4GHz TX/8ch Rx
    custom water pick up
    Rx power pack 1500mah
    Rx power switch
    octura x642 b/s
    Tupperware and bat trays removed
    turn fins shortened sharpened and angled
    foretrex 101 GPS
    all up run weight 5lb
    Maxamus
  • MAXAMUS
    • 210
    pics
    Maxamus
    • ozzie-crawl
      • Sep 2008
      • 2943
      havent got it in the water yet waiting for some parts to turn up
      6xl
      4s 2p 3700s
      200amp himodel esc
      prop v937
      inline cat rudder seperated for offset
      carbon fibre added to inside, battery trays removed, custom motor mount
      not sure on total weight yet
      • brad65
        • 172
        I didn't think carbon fiber was plyable? How did you reinforce with carbon fiber, could you explain more on the that?
        Pro Boat Apache 24 Brushless, Thunder Cat 31
        AquaCraft SV27, AqauCraft UL-1
        • ozzie-crawl
          • Sep 2008
          • 2943
          its carbon fibre cloth that you lay in and add your epoxy/resin same as fiberglassing
          • brad65
            • 172
            thats is so cool! how much weight and strength did you add?
            • ozzie-crawl
              • Sep 2008
              • 2943
              not sure how much weight i added, but strenghtend the hull a lot. i have seen photos of BJ that have flipped at speed and split at the front so added more resin and carbonfibre up there as well
              • Blackjack-sven
                • Feb 2009
                • 396
                My Blackjack 26 Brushless using Mamba Max ESC at 20 degree timing, 1500 KV motor, Stock Prop ,4900 Mah 22.2 v Li-po's and a Spectrum Telemetry Rx. It was clocked at 58 KPH (36 MPH) with a Bushnell Speedster Radar Gun.
                My new modded version has the Feigao 8xl motor, Hydra 240 ESC, Octura x642 prop, Trak Power 4900, 2s, 25c, 7.4v, Angled and raised turn fins, and weighing in at 5.1 LBS.
                It has yet to hit the water as the electronics need to be hard wired and the batteries need to be set in the hull. So as soon as I have that done and there is a nice day to drive it I'll take her out with my camera and radar gun and report the results.
                HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
                • brad65
                  • 172
                  interesting.... What did you do to the rudder? Is that a completly different setup or modded stock drive setup.
                  • Blackjack-sven
                    • Feb 2009
                    • 396
                    It's a completely different strut/rudder setup. I purchased it from O.S.E. (Product ID: tfl-502b15), and the tons of holes in the ass end of my boat are due to the other mod I did. I put three rudders on as I wanted the looks and the water pickups, but since I'm getting two new boats, I figured I would use the rudders for them instead.
                    • brad65
                      • 172
                      Very nice, I bet it runs night and day different than the stock drive setup. I have an apache24 that has almost the same rear u-joint setup rudder system as the blackjack26. I like this setup better than my half a** rig of locking the stock rear drive and adding a right side rudder. But it does drive much better though.
                      • Blackjack-sven
                        • Feb 2009
                        • 396
                        I'm hoping to see mid 40's to 50's with what I have in the boat, as with the stock equipment I hit the mid 30's. I'll be taking her out for her maiden run of the new equipment tomorrow.
                        Mid 30's
                        Stock motor
                        Stock prop
                        Stock ESC
                        2x 4900mah, 25c, 7.4v lipo's
                        Stock weight
                        Stock CG
                        Hopeful speed of 40's-50
                        Feigao 8xl
                        Octura x642
                        Hydra 240
                        5.2 LBS Wet
                        CG 7.5" from transom
                        • MAXAMUS
                          • 210
                          blackjack-sven
                          nice, keep us posted with speed trials i have yet to get a reading from my GPS i have now moved to 6cell 30c lipo, i had weight issues and think i have sorted this its now like a rocket will keep you posted
                          Maxamus
                          • Blackjack-sven
                            • Feb 2009
                            • 396
                            I went to the pond today to do test runs but I ran into two problems.
                            1. the drive flex shaft came out of the coupler leaving the motor spinning with the coupler.
                            2. The boat danced from right to left drastically, making a top speed run impossible.
                            I did however get a half speed run of 34mph before the shaft popped out.
                            Any thoughts as to why the shaft came out in the first place, and why the boat is bouncing left to right?
                            • brad65
                              • 172
                              Try removing the turn fins
