new boater with a q
  • dr.pringle
    • 12
    new boater with a q
    hey there after reading a whole crap load of forums ill still unsure on what batteries i should run. i want the most speed and run times possible with out blowing my boat up. what batteries should i get? do i have to make any mods to run them?
    thanx for your time dave
  • Punisher 67
    Ignore list member #67
    • 1616
    David a little more info on your boat would be a great help before anyone could recomend a battery
    • dr.pringle
      • 12
      It's a stock pro boat blackjack 26
      • dr.pringle
        • 12
        does that help
        • Punisher 67
          • 1616
          David I don't want to give you any bad advice since all of my boats are 10c to 12c range and from 45' to 60' in length . but if its any thing like the SV27 two 3200mah to 4800mah 3cell lipo's paralleled should probably work great , I hope someone with experience in the smaller boats chimes in to confirm or correct this . do a search on the Blackjack 26 on this forum there has got to be extensive info
          some good info in this thread.............http://forums.offshoreelectrics.com/...k+26+batteries
          • dr.pringle
            • 12
            Wow I think I'm in way over my head LOL oh well I'll figure it out
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              Actually, with repect Peter. He requires 2 3500mah or higher 1P in series. The motor is rated for 14.4v
              Douggie
              • Punisher 67
                • 1616
                Thanks Douggie for covering my butt...................
                • Ub Hauled
                  • 3051
                  I actually would go a step further and recommend 4500mAh or higher Douggie,
                  3500mAh is not going to give you too much of a run time.
                  • dr.pringle
                    • 12
                    so 2 7.4 volts 4500 mAh is what i need to buy?
                    • dr.pringle
                      • 12
                      7.4V 5000mAh (2 cells) Pro Power Series
                      Rating: 30C (150.0A) continuous, 60C (300.0A) burst
                      Dimension: 160mm x 44mm x 18mm
                      Weight: 265 grams
                      Termination: Wire & Thunder Power 4-pin tap
                      like these?
                      • Ub Hauled
                        • 3051
                        at least...
                        don't forget they have to be a high "C" rate (25 or more)
                        • dodge4x4
                          • 32
                          Doc those would be fine all you will have to do is change the plugs to deans plugs.
