You expert opinion - prop, strut, rudder choice
  • xletts
    • Jan 2009
    • 35
    Hi chaps,
    I have BJ26, hydra 120, stock BJ Motor and (after some kind advice from you'll) a 30C 5000mAh 4S Lipo on the way. I am now thinking about prop, rudder and strut choice. Any recommendations? I prefer to purchase from this site if possible and support this great forum!
    Many thanks,
    Shanus
  • calcagno45
    • Mar 2008
    • 1050
    scroll down to:
    Fuller's Offshore Catamaran Hardware. comes with a fully adjustable heavy duty strut and bracket, water pickup wedge rudder and mount, .125 flex shaft with 3/16ths stub shaft flex shaft, teflon liner, and fasteners
    Top quality, I think its almost a direct bolt up. A little pricey but GOOD!
    Or:
    http://www.offshoreelectrics.com/pro...ct-oc6str-130a
    Good, cheaper setup. Also has a skeg on the strut to help keep the hull going straight. Disadvantage is you'll have to add a water pickup, the rudder doesn't have one.
    As far as props, look for a x642.
    • MAXAMUS
      • 210
      Originally posted by calcagno45 View Post
      http://www.drcwebservices.com/ffe/hardware.htm
      scroll down to:
      Or:
      well what wlse can be said gets my vote
      maxamus
      BJ video http://www.youtube.com/watch?v=dDa5ZrCn81E
      Maxamus
      • Ub Hauled
        • 3051
        Chk this stuff out, I have my money on Speed Master hardware...
        the price is right and this is GREAT hardware.
        http://www.offshoreelectrics.com/pro...d=ros-21-strut
        • dodge4x4
          • 32
          I have the fullers strut and bracket with the speed master mini rudder.
          I like the offset rudder for speed
          • xletts
            • Jan 2009
            • 35
            Thanks for your responses all.
            Can someone explain what is the point of the strut? Is it just for added strength or are there performance reasons? I know the BJ uses the outdrive kind of like a strut and without it might be pretty week...what about a boat that uses a drive shaft tube...should it still have a strut?
            • dodge4x4
              • 32
              strut
              the strut is the bearing surface for the prop shaft it is something you have to have. Part of the drive line. the prop shaft spins inside of it and it is also where you adjust your prop angle of attack..
