speed estimate needed
  • MAXAMUS
    • 210
    hi all
    just looking for a speed estimate for my set up i just dont know what to expect before i was running the same set up but stock esc and motor and got 41mph measured with gps fortrex 101 new set up below...........
    AMMO 36-50 2300kv
    ETTI 150 amp ESC
    2x 6600 mah 20c lipo's
    x642
    fullers cat hardware
    thanks all
    Maxamus
  • MAXAMUS
    • 210
    i am just fresh back from the pond all though a 1/3 had a thin covering of ice which i found out when it was to late so on went the waders lol
    but after trimming out from my install of a spare 2.4ghz RX things went not to bad but iam still in need of some adjustments managed a rather dissapointing 35.1 mph
    the boat seemed to run alittle wet so i raised the strut but looking at it its at to much of an angle so i think it could be a weight issue here but all i have forward of the motor is my ESC batts are right back servo and RX remain in the stock position batt trays and servo box have been removed
    can some one just run by what effect tilting the strut has ?
    Maxamus
    • ApacheDude
      • Sep 2008
      • 88
      Did you recalibrate your ESC? Does the Etti have a calibration routine?
      Any pictures of the inside of the boat?
      Boats:
      Proboat Apache 24
      Proboat Blackjack 26 Brushless
      • MAXAMUS
        • 210
        yep esc was programmed after some teething trouble but the only fault i seem to have on that front is iam not getting a smooth throtle it only seems to kick in when opened to 1/2 on my futaba 6x 2.4ghz will need to look into that
        will take photos now and post in 10 mins
        Maxamus
        • MAXAMUS
          • 210
          ok here is the inside of my boat and the strut angle ??
          Maxamus
          • ApacheDude
            • Sep 2008
            • 88
            Not sure, it could be angle of the photo but check your motor to driveline angles for binding. In the second picture it looks out of alignment.
            Can you lower the strut so you have more of a straight line then angle the prop itself up?
            It seems to be sitting very high and that might cause binding on the cable too.
            I am no expert... maybe others have more info?
            Boats:
            Proboat Apache 24
            • ApacheDude
              • Sep 2008
              • 88
              Also check all your settings for the esc. Could still be a setting or issue with the esc?
              Boats:
              Proboat Apache 24
              • MAXAMUS
                • 210
                iam going to make adjustments now when i ran stock with the fullers and same bats iam pretty sure the drive angle wasn't like that its just trial and error but have posted more pics that may be clearer
                Maxamus
                • ApacheDude
                  • Sep 2008
                  • 88
                  I would try lowering 2-3 mm but still keep a slight up angle on the prop.
                  Did you check the motor connection angle?
                  Boats:
                  Proboat Apache 24
                  • MAXAMUS
                    • 210
                    motor to drive shart looks ok as i say its trial and error will do more testing at the pond tomoz
                    here are the photos after my adjustments
                    Maxamus
                    • ApacheDude
                      • Sep 2008
                      • 88
                      Good luck on the water! Looks better to me, but as you said, trial and error.
                      I am heading out myself tomorrow to beat on my new Hydra 120!
                      Let us know how the adjustments go.
                      Boats:
                      Proboat Apache 24
                      • MAXAMUS
                        • 210
                        yeah thanks man
                        will keep ya posted
                        what set up are you running ? and make some waves tomoz with your new ESC
                        Maxamus
                        • ApacheDude
                          • Sep 2008
                          • 88
                          Blackjack with stock motor and receiver.
                          Running 2S lipos
                          X642 prop, sharpened and balanced
                          stock drive hardware
                          New CC Hydra 120
                          See my thread on Baseline Blackjack
                          Boats:
                          Proboat Apache 24
                          • Jeff Wohlt
                            • 2740
                            You need some space between the drive dog and strut for sure. Minimum of about 1/8" and maybe a tad more. A cable shortens as it winds up and thrust is put on it.
                            Also, you have a bend going up to the strut...from the pics I see...adjust your stuffing tube so it is straight and inline with the strut nose...you are putting stress on the cable like that.
                            Lookslike you have a bunch of postive trim to the strut. Put it on a flat surface and then bring oyur strut up a couple mm but maintain flat.
                            www.rcraceboat.com
                            jwohlt5362@yahoo.com
                            • MAXAMUS
                              • 210
                              thanks for the info
                              have increased the gap between the drive dog and strut i to noticed that,
                              the stuffing tube where it leaves the hull is now been adjusted and is looking as flat as, but last time i had it set like this it ran wet hense the angle i had on the strut
                              i also gave everything a good check and i had previously installed a small peice of tubing over the stuffing tube where it joins the motor coupler to prevent water seeping in but have now removed this the drive shaft has been lubed and is free to spin no noises or binding
                              now only testing will tell i will report back tomorrow if the pond is not frozen lol
                              thanks all
                              Maxamus
