Running BJ26 with 6S Lipo?
  • Tony
    • 420
    Hey guys, some of you are running 6S Lipo with stock esc, and motor. I tried it yesterday, but it didn't run. How did you guys run it without any issues? I used Thunder Power Lipo 2 packs 3S 11.1v 2200mAh in series.
  • azjc
    • Sep 2008
    • 57
    I havnt done it so this is a guess, that the ESC won't arm with that much voltage and if there is a way to set the RSC in a manual mode might get it to arm
    • thrashmetal
      • 86
      re running your blackjack on 6s lipo
      i used the pro boat programming card to set my esc up.
      once i did that i was able to use 6s lipo and i ran it about 5 times then the esc wouldnt arm. so i reset the esc using the programming card again and it works once again.
      hydro & marine step 4 mono neu 1527 1y 6s
      blackjack brushless 26 bone stock 6s 55.4 mph
      ballistic racing team
      • Tony
        • 420
        OK , i have the programming card. How did you set it?
        • thrashmetal
          • 86
          setting up your esc with your programming card
          this is how i have my programming card set when i program my esc.
          battery type= lipo
          cutoff voltage=high ( this sets it at 3 volts per cell)
          cutoff type=slow down ( this will give you some power to still be able to drive the boat back to shore slowly if the lipo cutoff starts to kick in.)
          brake=off ( brakes are for pussies .lol)
          timing= high ( the stock motor doesnt seem to mind higher timing)
          throttle curve=linear
          this is the exact setup ive been using with my blackjack on 6s lipo and the only issue ive ever had is that i need to reprogram my esc from time to time.
          have fun tony.
          • Tony
            • 420
            battery type= lipo
            have fun tony.
            2x 3s 2200mAh 11.1v be ok? What lipo are you using?
            • thrashmetal
              • 86
              re lipos
              im using a pair of 3s 3800 lipos.
              any pair of 3s lipos will work.
              • 6S HYDRO
                • 1325
                ran 6s yesterday w/ stock bec, no problems no heat issues
                • MAXAMUS
                  • 210
                  iam waiting on a set of 3 cell 11.1v 4000Mah 30c lipo's arriving and will see what results i get from them hoping to see a remarkable increase in speed from what iam running now but to confirm what should the cut of be set to ??
                  bj26
                  fullers o/s cat hardware
                  ETTI 150 amp esc
                  2x 6600 mah 20c lipo (soon to be 2x 11.1v 4000Mah 30c)
                  futaba 2.4GHz TX/8ch Rx
                  custom water pick up
                  Rx power pack 1500mah
                  Rx power switch
                  octura x642 b/s or x640
                  Tupperware and bat trays removed
                  turn fins shortened sharpened and angled
                  foretrex 101 GPS
                  all up run weight 5lb
                  Maxamus
                  • Meniscus
                    Refuse the box exists!
                    • 3312
                    Please read the specs on the Brushless ESC in question:
                    45-Amp Brushless ESC
                    Specs
                    • Forward:Yes
                    • Brake:Yes
                    • Continuous Maximum Current:45A
                    • Input Voltage:Minimum 10V, Maximum 21V
                    • Momentary Peak Current:55A
                    • BEC Voltage:5.8V
                    I think that if you are running 6s at 22.2 Volts (nominal), then you should be prepared to replace the ESC. Another consideration, I haven't checked, but this ESC may only be setup for 4s, so your lipo cutoff could be in the dangerous range if the cutoff voltage is 9.6V for 6s. This would mean that the ESC would cutoff at 1.6V per cell. If this is indeed the case, then you should be prepared to replace your lipos as well, granted there's no fire. If there's a fire, then you may be in for the whole boat.
                    Like I said, I haven't confirmed that the ESC cutoff doesn't change according to the input voltage. Perhaps it does. Maybe someone else can weigh in here.
                    • 6S HYDRO
                      • 1325
                      all i know is it works
                      • Meniscus
                        • 3312
                        I know, I just wanted to caution those who read this thread now or later on.
                        • 6S HYDRO
                          • 1325
                          did you try the zigzag 3 cell yet meniscus?
                          • Flying Scotsman
                            Fast Electric Adict!
                            • 5195
                            You guys are idiots for posting this type of info. Now every RTR newbie boater will push their equipment way over their designed and engineered specifications
                            Douggie
                            • Meniscus
                              • 3312
                              I wanted to see how you did on a longer run first, LOL That way, if it goes, I can reconsider
