help needed iam stumped !!
  • MAXAMUS
    • 210
    Hi All
    OK being fairly new to Fe boats i have now hit a buffer which has stopped me in my tracks as some will know from my previous posts i was swapping out the stock motor and ESC and up grading, due to waiting on parts this is now done my AMMO 36-50 2300kv is fitted along with my ETTI 150 amp ESC
    all secure and connected up but i have no power at all !!
    iam still using the stock Rx but as we know the stock ESC had a on, off switch and as iam not that great in the electrical department did this power the stock RX IE is this why i don't have any power ? ??? please help
    thanks maxamus ............
    Maxamus
  • egneg
    • 4759
    I think you will need a receiver pack with that ESC.
    IMPBA 20481S D-12
      AFAIK all the ETTIs have a BEC, so a receiver pack should not be needed for it to work in your boat. The ESC may be set with a voltage cutoff that is too low for the packs you are using. When you turn on the radio and plug in the packs does the ESC beep? Is the ESC plug in the receiver correctly polarized/inserted? If all else fails, read the directions; these should work for the 150 if you don't have them.
      • MAXAMUS
        • 210
        no power nothing no beeps using fully charged bats tried swapping Rx plug about 180 o and plugging back into Rx still nothing
        Maxamus
          - Do you have steering?
          - Did you ever connect the ESC to the packs backwards - even for just a second?
          - Is your transmitter set to full throttle/full brake with trim in the middle?
          - Are all three motor wires connected when you are plugging in the packs?
          - Did it ever make a sound when connected?
          • wf6h
            • 27
            Not a lot of info but looking at the picture! I see one battery and a Series harness! Unless I just don't see the other battery?
            • MAXAMUS
              • 210
              the photo was taken after i disconnected 1 of the packs i am using 2x 7.4v 6600mah 20 c packs in series there are no beeps, sounds, nothing dead as a dodo
              Maxamus
              • wf6h
                • 27
                OK then! Well I'm at a loss then.. Someone will come along with the right answer.. Good luck to you..
                Ken
                • egneg
                  • 4759
                  The 150 amp listed here does not have a BEC.
                  http://cgi.ebay.com/ETTI-150A-30V-6-...742.m153.l1262
                  IMPBA 20481S D-12
                    Okay, then all the OP needs is a receiver pack...that's easy.
                    • MAXAMUS
                      • 210
                      OK guys your loosing me here would a bec sort it out and what about a rx power pk where, what and how ??
                      iam in comms with ASTEC who i bought it from and he hasn't come up with anything either my next thought would be the soldering ?? poss dry joint or bad solder ?? its making me mad now
                      Maxamus
                      • Spot Me 2
                        • 770
                        Add a receiver pack and see if it works. It has no bec, or battery eliminator circuit. It needs a Ubec or receiver pack.
                        MMGMMarine
                        RobertsonRacing
                        • NorthernBoater
                          • 869
                          Try something like this, http://www3.towerhobbies.com/cgi-bin...battery+holder. Your LHS should have something that will work.
                          • rockwerks
                            • 772
                            Most RC car and truck esc's are made with what is called a BEC circuit in the esc. Battery Elimination Circuit). This circuit makes it possible for you run the radio equiptment wiout the need for adding a receiver pack of batteries and plugging it into the receiver where it says BATT.
                            You have 2 ways to overcome the problem.
                            one is to put in a 4 AA cell receiver pack into the the receiver, that pack will then power your radio equipment.
                            The other option is to install and external UBEC (universal battery elimination circuit). This little unit taps directly off the +and- battery leads to draw power from the packs and plugs into the BATT port on the receiver, it converts power the correct voltage to properly run the radio equipment. If you go this route make sure you have one with a high enough amp rating to handle the load
                            here is how to wire it in:
                            an RC rock crawler lost in a sea of boat parts.........
                            • MAXAMUS
                              • 210
                              well i have a Medusa bec 2amp bec(6v) from an aero project also an opto isolator would i need that to ?
                              Maxamus
