Esc Testing Blown Or Not ??
  • MAXAMUS
    • 210
    Hi guys
    well to cut a long story short my ESC seems to have died ! after a capsize all dried out for nearly a week
    symptoms - 2x fresh charged lipo's 7.4v connected
    TX switched on then power on, no beeps from ESC or throttle but power to servo
    tests Ive carried out
    swapped out the Rx to a futaba fasst 2.4GHz powered up same as above servo working ,still no beeps from ESC or any throttle ,then i reprogrammed the ESC and get the conformation beep that it has been performed successfully but still no throttle and still the servo works
    OK so servo is fine i have a aero ESC i could test it with but it would mean having to swap the male connectors and solder 3 female bullet connectors on to be honest i cant be bothered to go to all that effort tomorrow i will get out the volt meter and see if there is any power output from the ESC throttle cable to Rx and then failing that i have this in mind
    ETTI @125a water cooled ESC
    http://cgi.ebay.co.uk/ETTI-125A-Wate...742.m153.l1262
    have read some good reports on this input from anybody using one of these would be great and AS ALLWAYS I VALUE ALL INPUT
    thanks MAXAMUS...........
    BJ 26 VIDEO http://www.youtube.com/watch?v=dDa5ZrCn81E
    Maxamus
  • Rex R
    • 1007
    try swapping esc and steering (although if you have already tryed a different rx that might not tell you anything). if the rx powers up and you have steering then either the signal wire to the esc is kaput or the esc is...likely you need a new esc.
