motor question
  • crazzy maxx
    • Dec 2007
    • 498
    motor question
    hi
    i am planning on runing 2 3100 14.8v 4s1p lipos in my bj. i have a barricuda 125 esc with a y harness. do you guys think the motor will hold up?
    snort pixi sticks=symptoms-:
  • thrashmetal
    • 82
    re stock blackjack motor
    i wanted to run 3s lipos with my blackjack and a tech from pro boat told me it would cook the motor.
    you have a great esc in the barracuda so you should upgrade your motor also.
    hydro & marine step 4 mono neu 1527 1y 6s
    blackjack brushless 26 bone stock 6s 55.4 mph
    ballistic racing team
    • MAXAMUS
      • 200
      But what is the hot set up motor for this ???
      Maxamus
      • ax10ny
        • Sep 2008
        • 2
        ive run the stock motor and esc on 4s lipos with no problems so far. the stock motor is 1500 kv so it spins about 22k rpm on 4s lipos. i did have motor temp issues but i turned the timing on the stock esc from low to high with the program card and temps dropped greatly.
        i have a hydra 120 that i run a feiago 9xl with on 4s 8000's with a grimracer 40x53 copper prop and see speeds in the low to mid 40's and it gets out of the hole alot better than with a 42x55 or a 42x66.
        • MAXAMUS
          • 200
          hi all
          so i now have in my possession my new 150 amp Etti esc and iam just waiting on my ammo 36-50-2300 motor to arrive should be here at the start of next week
          any suggestions on a good lipo set up to wake this thing up and make it rock ??
          maxamus's bj 26 vid http://www.youtube.com/watch?v=dDa5ZrCn81E
          Maxamus
          • Steven Vaccaro
            Administrator
            • 8724
            Originally posted by crazzy maxx View Post
            hi
            So you will be running 8s in total? Thats a ton of rpm. More than safely recommended for the motor.
            Steven Vaccaro
            • tth
              • Apr 2008
              • 1510
              WITH STEVEN ALSO. NOT TO MENTION MORE THAN THE ESC CAN HANDLE. IT WOULD BE OK TO RUN THE PACKS IN PARALLEL OTHERWISE
              • ChaKane
                • 131
                8S with that motor (3100) gives 91760 rmp, way too much to do any good for anything. Crazy, I'd either back off on the voltage or switch the harness over to a parallel configeration. This would give you 45880rpm. Still a little high but usable.
                • kookie_guy
                  • 897
                  considering you mentioned that you'll be using a y connector, I'm going to assume you are running them in parallel, in which case it would be totally fine, since it's still just 14.8 volts, but double the run time. If you are planning on running them in series as mentioned (8s, 29.6 volts) bring a fire extinguisher
