maxamus 1st BJ26 video
  • MAXAMUS
    • 210
    Hi All
    well its been a long time in the arrival of this video not in HD as i said, still waiting to get a hard copy of that, but in the mean time here is my first video of my BJ26
    still looking for that sweet spot but GPS'D it today at 40mph with a foretrex 101
    but i noticed alot of fine stringy weed catching on the fins but now i have a ball park figure i can start small adjustments and see if it improves a bit
    running
    fullers cat hardware
    octura balanced and sharpened x642 prop
    removed bat trays
    re positioned antenna
    blocked old antenna hole and cockpit air scoops
    custom made water pickup
    2x 6600mah 2s lipo's 25c
    shortened fins
    and on board foretrex GPS 101
    the rest is stock
    so here is the link enjoy ( just under where it says views remember to click on watch in high quality)
    http://www.youtube.com/watch?v=dDa5ZrCn81E
    Maxamus
  • MAXAMUS
    • 210
    Just back from the pond not much of an improvement on yesterdays speed run of 40mph
    last night i lubed the flexi drive and double checked that it was free to rotate and parallel when re assembled i wasn't out to make any adjustments to the strut or rudder but the speed increased by just .2 without doing anything so 40.2 mph iam looking to increase on this somewhat but as a newbie can someone post the finer points of adjustments to the strut IE what effect it has on being higher or lower and angled with up tilt or down tilt ? and with my set up what realistic speed do you think i could achieve ?? would be interested in your views
    thanks Guys ........ Maxamus
    Maxamus
    • obrien
      • Nov 2007
      • 1320
      detounge the prop
      that will help a bit
      • Jeepers
        • May 2007
        • 2050
        Try other props than the 642,
        I like the Octura 4 series props on my race boats.
        • Apples1
          • Dec 2007
          • 418
          get rid of those Silly fins! add almost 3-5mph without them, the higher you adjust the strut the higher the boat will ride, but the less unstable it will be , for straight line i have my strut up high, but for circuit i keep it fairly neutral.
          IMO those fins just make the boat "crab" around the corners the BJ26 with a good offset rudder shouldnt need fins or trim tabs, i have no problem turning sharp at full pace without flipping.
          I am a big fan of the 642 detounged and cupped a bit, cupping it will increase the pitch, the x645 is also great. have'nt tried my worked 645 yet but should be quich as well
          returning to boats after a big break
          • ETOWNE
            • Mar 2008
            • 299
            I agree w/ APPLES, get good hardware and lose the fins.Worth 3mph on my boat.
            Vortex 22 hydro ammo 36-50
            Vortex Cyber Storm 33 P spec Mono AC 36-56
            PT SS-45 Q-hydro Neu 1527/1Y
            • MAXAMUS
              • 210
              thanks guys
              Ive got the hardware, fullers in line but it now looks like iam going to play about with the strut first raise it a bit then look at propnutt's angling of the fins to see what difference that makes, then no doubt remove them all together but will also invest in another prop but detounged this time everyone seems to be running the 642 apples1 has a 645 as his post
              hmmmm decisions will look into it and report back
              but thanks again for the comments
              maxamus......
              Maxamus
              • MAXAMUS
                • 210
                bad weather in town not so good for flying or boating
                looks set for the forthcoming week Dammit !!
                Maxamus
                • MAXAMUS
                  • 210
                  Weather is looking good for tomoz
                  hoping new props will arrive as well
                  have on order octura x642 DE tongued balanced and sharpened
                  --------x645 ----------------------"-----------------------
                  looking forward to seeing any changes in GPS speed would love to break the golden 50 mph currently sitting at 40.2 mph
                  fullers off shore cat hardware
                  2x 2s 6600mah 20c lipo
                  shortened fins
                  x642 balanced sharpened and polished
                  fins soon to be removed !!
                  maxamus BJ video http://www.youtube.com/watch?v=dDa5ZrCn81E
                  Maxamus
                  • MAXAMUS
                    • 210
                    well props never arrived this morning disappointing but i started out today to complete the fin mod
                    so now this is complete fins angled inwards and parallel with the outward step of the hull and shortened i can tell you i thought i was in for an easy ride the first fin unscrewed with no problem the second fin the 1st screw came out no bother and i thought iam on to a winner until the last one and we all know what happens there
                    anyway all complete and iam off now to the pond GPS in hand and will report back with any handling issues and speed data
                    maxamus
                    Maxamus
                    • MAXAMUS
                      • 210
                      Not a good session down at the pond possibly due to the fact i should have done a water tight test before i set out on my run you learn by your mistakes
                      So things started off well, the boat was running well and the angled fins have made a substantial change in the cornering, more stable and sharper. Then i noticed that it was running wet thought that it was due to the fact i had set up wrong so i came in a little closer and gave some gas and it flipped some 25m out so i sent in the recovery boat and pushed it back to shore, well not good opened the hatch and there was enough water for a shower lol so back at home dried everything out and filled a basin with water and noticed water was seeping in on the left side of the fin have now stripped it all back down dried it out and made adjustments on the fin and used sealer around the fixings inside the hull just need to let that dry out and re check
                      well that was my first flip and i hope i don't have anymore
                      Maxamus
                      • MAXAMUS
                        • 210
                        no power help please
                        Well things were all going good there for a moment a leak around one of the fins was rectified sealant applied to other areas tested at home all OK so off to the pond checked again servo fine, throttle OK. GPS in , hatch taped down any a little push and i was set, 3 or 4 short runs up and down nothing to drastic then nothing no power no servo nothing dead in the water. Rescue boat was dispatched good job i charged its battery up this morning retrieved ,hatch off no sign of any water bone dry, now it has me stumped .........any thoughts ????
                        Maxamus
