BJ26 Motor on non-stock ESC??
  • Darin Jordan
    • 8332
    I know that alternate ESCs seem to get hot when used on the SV27 motor...
    Has there been any issues with running other-than-stock ESCs with the BJ26 Motor?? Barracuda 125s or Hydro 120s, etc?? Do they work fine with this motor or do they get too hot??
    Thanks,
    Darin E. Jordan - Renton, WA
  • obrien
    • 1264
    I have run the hydra 120 on my stock bj with no issues as all.
    • RCprince
      • Jul 2007
      • 1637
      I Run My Ob Bj With The Stock Motor And A Barracuda 125
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • RCprince
        • Jul 2007
        • 1637
        dARIN THE bj MOTOR COMPONENTS IS WAY BETTER THAN THE sv THAT ONLY ADVANTAGE I'LL GIVE THE SV IS DRIVE HARDWARE
        • ReddyWatts
          • 1700
          IMO, the BJ & SV motors are 6 pole, so the controller pulse frequency is 3 times as fast as a 2 pole motor at the same RPM. It also has to stay in correct timing with the rotor at a higher freq. Their controllers were specifically designed for 6 pole motors.
          Some controllers handle more poles better than others.
          ReddyWatts fleet photo
          • RCprince
            • Jul 2007
            • 1637
            Himax which seems to be the manufacture of the BJ motor recommends CC esc's and default settings
            • RCprince
              • Jul 2007
              • 1637
              I got 48.2 mph today on my SV running a BJ motor, Cheap 60amp esc, x440 6s 2200 25c
