BJ26 ESC on 6S?
  • ReddyWatts
    • 1700
    BJ26 ESC on 6S?
    I read that a BJ26 stock ESC/motor can handle 6S without BEC........???
    Has anyone run theirs on 6S successfully?
    Which prop?
    ReddyWatts fleet photo
  • Jeff Wohlt
    • 2716
    No...that is WITH bec.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • Steven Vaccaro
      Administrator
      • 8724
      WOW REALLY? Who did it? I have a couple of those going in my old twin outboard Titan 40. Now you have me more intrigued.
      Steven Vaccaro
      • RCprince
        • Jul 2007
        • 1637
        When I first had my BJ I ran it on 6s my cousin let me try out one of his packs that's when I did 51 plus before it blew over, everything was stock, with the exception of the 645 prop.
        Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
        • ReddyWatts
          • 1700
          6s with BEC
          My Gosh.................... that makes it more incredible!
          They really over built this ESC.
          This info is tempting me to put 6s in a Miss Budweiser with the BJ motor/esc combo with BEC.
          For the new guys:
          BEC (Some ESC's have a built in "Battery Eliminater Circuit", to power the receiver on the middle red wire going to the receiver.
          Disconnect this wire for (without BEC) if you want to use an external battery to power the receiver or you may also purchase an external BEC to power it.
          • Teerayoot
            • 20
            Just burnt for me already with 6S lipo,
            i replace with SV27 ESC also burnt ,
            so i ordered HV120 version ,will try soon .
            สวัดดีครับ
            • RCprince
              • Jul 2007
              • 1637
              What motor was you using and what size prop
              • Teerayoot
                • 20
                Both all stock part,or just too much battery C ratting,
                I'm using 30C ratting serial with 25C 2 pack of 11.1V lipo.
                Anyway do this (burnt ESC ) is warranty void?,if not i will taking a claim.
                สวัดดีครับ
                • RCprince
                  • Jul 2007
                  • 1637
                  well with 6s it's void...max voltage they recommend is 21
                  • RCprince
                    • Jul 2007
                    • 1637
                    5s is Ideal...I've read a few post where you can get 50 plus out of 5s and stock set up
                    • Teerayoot
                      • 20
                      Thank for so far reply.
                      I have some question,
                      How much stock motor can handle for Voltage and AMP,
                      because of i plan to using 6S lipo stock motor with
                      Castle Creations Hydra High Voltage 120
                      http://www.offshoreelectrics.com/pro...ra120-highvolt
                      Don't sure it can hanle so much voltage,so much cost alredy pay for .
                      If speed isn't satisfied i also plan to using 12S lipo(2 22.2 lipo pack) :)
                      Hope motor can accept it ,wanna to get some break record ^^.
                      สวัดดีครับ
                      • RCprince
                        • Jul 2007
                        • 1637
                        Well if the BJBL motor is truly a HIMAX motor it says they can run up to 40,000 rpm max, not sure if that a bearing limitation but 40,000 rpm is over kill anyway, 30-35k is ideal..I think 6s is the most you'd wanna put on that motor anyway, with a 640 and down prop. 12s on that Motor...you'd fry it completely...the wires are to thin to handle that kind of amperes and voltage...
                        • crazzy maxx
                          • Dec 2007
                          • 498
                          i just ordered 4s1p max amp lipos 2 of them should run nice right?( i ordered them for my mhz flash ) figured ide try them in my bj
                          snort pixi sticks=symptoms-:
                          • birdy233
                            • 162
                            Quick question,
                            I have a pair of 5000mah 2S1P's that I normally run in my BJ26. I also have a 3S1P 5000mah pack, could I run one 2S1P and the 3S1P for a total of 5S1P? Will this work out ok? That would put total voltage at 18.5
                            Thanks!
                            • RCprince
                              • Jul 2007
                              • 1637
                              It should work, the amps are the same voltage will be the only increase
