Got a problem need HELP!
  • Tony
    • 420
    My bj26 is doing fine. Its just my other cat that i need help with. Here is the problem. The boat seems to work fine when out of the water. Motor runs, esc responds, servo working. But, when i put the boat in the water it runs like the batt is about to die. Checked the batt, and it is fully charged. So what could be wrong?
  • chirotray
    DocFowler
    • 139
    need more info. esc? motor? bat? Prop? drive line condition? did you check battery static or under a load?
    Yes its fast, yes it will go far away, yes its expensive. No you cant try it.
    • Tony
      • 420
      Everything new.
      Water-cooled 2618 KV Brushless In-Runner Motor
      50Amp Water-cooled Brushless Electronic Speed Control , seperate BEC
      Thunderpower 2200 11.1V
      2 Blade Chopper Propeller , Octura X642
      I did tighten the flex shaft, because i thought it was loose. But, the boat still runs so slow.
      • chirotray
        DocFowler
        • 139
        Do you have another battery to try?
        • Tony
          • 420
          Yes. I tried it with another fully charged batt. Same result.
          • chirotray
            DocFowler
            • 139
            Ok, how about your radio program? End-points, atv, expo, etc.? Everything normal? What brand esc is it?
            • chirotray
              DocFowler
              • 139
              What is the boat? And are you only running one 3s?
              • Tony
                • 420
                Its a 32" cat. No idea what brand esc. I am running one 3s batt
                • chirotray
                  DocFowler
                  • 139
                  Off the top of my head, if every thing is functioning ok.......you need MORE battery. One 3s is slim pickings, not to mention its only a 2200. My blackjack runs 4s at 5000 mah. Was this boat ever fast on one pack, or is it a new to you boat?
                  • Tony
                    • 420
                    It is new to me, and it was fast on one pack. It was recommended by rchobby centre to use one 3s pack lipo.
                    This is where i got it from.
                    http://cgi.ebay.com/ws/eBayISAPI.dll...link:middle:us
                    • chirotray
                      DocFowler
                      • 139
                      I like that hull alot! How much did you pay it for? And for the problem, We dont know ANYTHING about the esc., that makes life hard. I dont understand only using one 3s pack. Weird. Make sure youre arming it properly, and check your pack voltage under a load. A lot of bad cells read normal just sitting on a table, then under a load they crap out. Make sure all you adjustments on the tx are neutral, or 100% depending. From there i cant be much more help without knowing more about the esc.
                      • Tony
                        • 420
                        I paid $390 include shipping from down under to USA. IF, i have to change out the esc. What would you recommend?
                        • chirotray
                          DocFowler
                          • 139
                          A castle Hydra. Theres a few levels of them, depending on how extreme you wanna be. Put one of those in there and a pair big lipos, and hang on! Id try to contact them first though, they said theres no instructions because theyre here to help, so call em up!
                          • Tony
                            • 420
                            Yea, they give 12 months warranty on the boat. So, hopefully they'll fix it. Anyways, thanks for trying to help me out.
                            • chirotray
                              DocFowler
                              • 139
                              No problemo, good luck.
