My Blackjack w/ TLR Outdrive & Lipo
  • Anthony.L
    • 18
    Hit My Mark!!!
    Decide to charge the batteries and go back out again today. I really wanted to reach 55mph.
    The changes between the last run of 52 and this one was removing the radio box, lowering and moving the ESC towards the transom. Then I moved the batteries back approx 2" from the stock location. Went out and first pass almost full throttle the boat blows over. Check the GPS and it blew over at 52.8mph. Ok, so I'm going faster but need to keep the boat in the water. So I move the batteries forward, now approx 1" back from the stock location. This time much better, the boat is lighter in the water but does not blow over. Do a few good runs and break 55mph, very happy!
    • Anthony.L
      • 18
      Originally posted by Apples1 View Post
      however this weekend every time i ran my 645 my main (blue) motor wire kept on coming unsoldered(at the bullet connector) , maybe a heat issue, but nothing is running to hot. a bit puzzleing?
      Can you get solder that melts at a higher temp?
      I can all but guarantee you are not unsoldering the bullet due to heat. With the distance the bullet is from the motor you would have to get the motor north of 250 F to unsolder it.
      Honestly, my guess is you had a cold solder joint, or simply not enough solder and it's working it's way loose more from vibration then heat.
      You can get high temp solder, but it's hard to work with and requires a very hot iron.
      • Anthony.L
        • 18
        Originally posted by Wakesurfer View Post
        I like that little Garmin. My old Magellen is to big and heavy to put in my RCs. Might have to get one of those.
        The Garmin Foretrex 101 is my first GPS handheld. I was watching several YouTube videos and saw a bunch of people using that model so I figured it had to be good. I think it's perfect size and does exactly what I want to record. I plan to try it out in my planes and helis next just for fun.
        • RCprince
          • Jul 2007
          • 1637
          Congrads on your high mark...do you think 60 is possible....I think so
          Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
          • Anthony.L
            • 18
            Well....I said once I get 55 with this boat I would move on. However I'm having so much fun I want to try for 60. I think it's doable but it's going to be much harder then reaching 55. Plus I've only got 4 battery packs on the boat and having a blast.
            So I'm thinking about trying a couple things. First order a couple more prop options, x445 and x645. Then maybe look at getting some Fuller hardware that moves the strut farther off the transom to let the prop have more leverage on the nose.
            Then my secret weapon if all else fails is a Neu 1515/2.5D/F I have laying around from one of my helis.
            • hex-dj
              • 238
              Anthony .L .......Running all stock he s doing great (55 mph all stock wow!),but if he buys an OSE straight coupler,lighter servo,remove all the stock stickers and maybe add like 4-6 little new ones ,add a sleeve bearing/bushing to that TLR system ,remove the canopies from the hatch ...then he should be doing around 66 +- mph.
              • Mich. Maniac
                • 1384
                Oh dear! Here we go again
                • frdvschvy
                  • 60
                  66mph is yesterdays news. I removed the hatch completely, removed the servo sticker, removed lipo battery shrink wrap, and rain-x the entire hull (including the top). Was able to go 73mph with these mods (sorry no video but I can take some sweet still shots!).
                  • hex-dj
                    • 238
                    What is it with you two Itch. Brainiac and hondavstoyota ? You know who you are ,trying to make fun,ask an expert a real one that is and he may tell you a tip or two that you actualy obviate when making rtr boats run faster even the ones built from the ground up by yourselves. I am still waiting for my radar gun patiently...duhhh!And I wrote more or less see + - mph
                    • Mich. Maniac
                      • 1384
                      This is what ruins perfectly constructive forums. I have absolutely nothing else to say so good luck to all and make sure your STICKERS are in the right spot!
                      • chirotray
                        DocFowler
                        • 139
                        See, there goes that damn trick birthday candle again..........everytime you think its out..........poooof!! Flames up again!
                        Yes its fast, yes it will go far away, yes its expensive. No you cant try it.
                        • hex-dj
                          • 238
                          When I post a vid. and some pics about my radar gun s mph real results it will resurface again... ultra mod vs. extreme mod remember? ...ohhh and know this, soon I will be the proud owner of two Neus 1512 2D 2600 KV with some new versions of the CC Hydras 120 s and 6s Lipos with 8000 mah s to mount on my SV 27 ,BJ 26 EPs or simply just make a new twin Neu super project... Hahahaa see you in ... hahaaha.LOL ...I "guess" it will be Chiro vs. Mich. soon. Hahaaha!
                          • chirotray
                            DocFowler
                            • 139
                            Wow. Outta control.
                            • hex-dj
                              • 238
                              Originally posted by chirotray View Post
                              Wow. Outta control.
                              Realy?
                              • H&MWill
                                • 623
                                Wow. Charles Manson, when he WAS allowed to do interviews, made more sense than the crap that spews out of you.
                                Many issues!!!
