Just bought 2 new BJ 26 and they both shut off at full throttle! Spent around 900.00 for the boats and batteries and chargers to give me and my daughter some time to spend together and they both suck! My local shop says sorry they are yours now no help at all please someone help.
What a drag
yep that the ESC's you might want to invest in the program module and turn off the high volt cut off, Check the thread on the ESC shut down in the BJ category maybe you can get something from there. My Bj ran the beast on fully charged 14.4 volts 4200's mah tenergy batteries. I would get 12-15 min runs befor it cut out like that. Well good luck
http://forums.offshoreelectrics.com/...ead.php?t=1677 these guys had the same issue, but looks like someone found a solution in here.
Mine Did The Same Edzact Thing And It Was B/c The Batteries I Where Running Didnt Supply Enought Power.snort pixi sticks=symptoms-:
mine too, but to get you gong before you get a programing module, have your controller turned on and you boat turned on and have someone hold full throttle when you plug in the second batt, and hold it untilll you hear a series of beeps (abtou 3 - 4 Seconds)
That will reset the factory ESC setting to a higher cutoff limit.(for that run only)
Good luck, let me know how you go.returning to boats after a big break
definitely invest in some good IB cells. or some packs like Steven sells here in the store. Much better amp draws on the packs to give more power!!!My prop hasn't been wet in a while.
