Has anyone of heard of any issues with the esc on the Blackjack? We bought three of them in the fall and two of the boats keep cutting out on the throttle. They have never been underwater, they are stock, running nimh batteries. I did tweek the esc setting with the supplied programming tool. Any ideas?
Problem with ESC - stock boat
i have had the same problem, it was either one of two things,
1, there is a crapped out cell in one or both of the packs, effecting full throttle voltage (not enough) or
2, the high voltage cutoff is set to low, to fix this with the reciever / Boat turned on, hold full throttle and plug in the packs and hold it untill you hear a tone (about 3 - 4 seconds)
some venom batteries i have heard have been dodgey. from brand new!
Good luckreturning to boats after a big break
re blackjack esc issues
for sure its the esc needing to be re programmed . there are lots of blackjack owners having esc problems .
as long as you have the programming card to reset your esc you should be good to gohydro & marine step 4 mono neu 1527 1y 6s
blackjack brushless 26 bone stock 6s 55.4 mph
ballistic racing team
very helpful as im having issues ith cut out on nimhs... will try the trottle hold and arm.
Anyone know how to set from nihm to lipo without the programming card? as mine will not be here till sometime next week
and my lipos are sitting here ready to go.
My friends Formula Fastech and my Blackjack had similar problems. In our cases, we had packs crapping out.
The current draw on the stock setup is much higher that I first expected. This boat will break less than perfect packs. Just my opinion.
Once I found good packs I got solids runs. Once I switched to high capacity lipos it was night and day difference in runs.
I am sure the programming is also at play but make sure your batteries are truly top notch.Boats:
Proboat Apache 24
Proboat Blackjack 26 Brushless
