OutBoard BlackJack
  • calcagno45
    • Mar 2008
    • 1050
    #31
    cool. I'll either buy those or try:
    http://www.offshoreelectrics.com/inf...propellers.php
    • RCprince
      • Jul 2007
      • 1684
      #32
      Well I'd try that the adapter first, The Black Jack uses one, it's shaft is 1/8th, I'm not sure if there's enough length on the ep1 shaft though to fit a 3/16th prop hub.
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • calcagno45
        • Mar 2008
        • 1050
        #33
        sounds good. using those adaptors I should be able to run CF40 props couter rotating.
        • RCprince
          • Jul 2007
          • 1684
          #34
          Thats the octura shaft and a x645 cut down and detongued to a x640
          • calcagno45
            • Mar 2008
            • 1050
            #35
            check this one out:
            http://cgi.ebay.com/Custom-Built-30-...QQcmdZViewItem
            what props does that look like?
            • RCprince
              • Jul 2007
              • 1684
              #36
              those look like 430's the problem with a vee hull is the chine walking..I've tried and given up...A cat has 2 hulls to displace the the prop walk better, but it looks cools though..I like to see it run, by looking at it's setup the batteries toooo far back.
              • Eodman
                • 1285
                #37
                Well guys I took my cat out at lunch for a quick test drive .... well everything got real warm - esc shutdown ...etc...
                RCprince could you post a couple of close ups of your cooling solution? I think the motors aren't get enough water to cool them down!
                I upgraded to Reedy Spec 19 quad mags & when I put the cooling coils on them they probably are not tight enough! I'd try the silicone cooling jackets that Steve sells if I can figure out the correct size! Any help ????
                We did it with a Bang!
                Cats Are Where It's At!
                • RCprince
                  • Jul 2007
                  • 1684
                  #38
                  I'm using a BJ Motor http://www.offshoreelectrics.com/pro...rod=dh-prb3310
                  which looks like a himax 6 pole 3630-1500 which is 87% efficient and a CC Barracuda 125 cooling is not an Issue...i'm not sure if those 19's have enough torque to be efficient enough to push that hull, what size props are you using....
                  • calcagno45
                    • Mar 2008
                    • 1050
                    #39
                    Well guys. I just got my order of 2 EP1's in today and I must say I'm impressed. They are way bigger than I thought they were. I can't wait to mount them on a hull. I decided to rebuild my Skunkworks with the 9xl and stuffing tube set up. So now I need a hull to put them on.
                    Any ideas/suggestions on a good hull?
                    • RCprince
                      • Jul 2007
                      • 1684
                      #40
                      If your gonna run the 9XL your gonna need to drill out the drive dogs...and you gotta re mesh those gears right or you'll be Steve's best order buddy.
                      • jeff180
                        • 150
                        #41
                        So when you gonna run it?
                        sad
                        • crazzy maxx
                          • Dec 2007
                          • 498
                          #42
                          ok enough picsture and talk GET A VIDEO!!!!!!
                          snort pixi sticks=symptoms-:
                          • RCprince
                            • Jul 2007
                            • 1684
                            #43
                            I love it
                            • calcagno45
                              • Mar 2008
                              • 1050
                              #44
                              Nah, I'm not throwing the 9XL in there. I'm looking for a good hull to run the dual EP1's on now.
                              I already have someone making the "Merc 2.5" sticker kits for it. LOL
                              • Eyekandyboats
                                • 1935
                                #45
                                i dont know . out boards are just not for me. they look out of place and you cant hang as much power as you can mount inside a hull. :)
                                EYEKANDYGRAPHICS
                                www.rclipos.com
