Blackjack Flex Drive
  • MORIDE
    • 108
    Just purchased a BJBL and was thinking about replacing the U joint with a flex drive. Seen several post, but does someone know the exact parts I will need to upgrade this?
  • RCprince
    • Jul 2007
    • 1684
    This is the kit I used http://www.offshoreelectrics.com/pro...oct-oc150L-24c
    Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
    • Tony
      • 420
      Can i install this Flex shaft directly to the stock rudder, or do i need to replace the stock rudder as well?
