BlackJack SS Conversion
  • Camaroracer
    • May 2011
    • 22
    I bought a used BlackJack about 3 weeks ago as my first hobby grade boat and was going to keep it stock
    The first thing i did was get rid of the radio box. Then the next run i sunk it and realized i fried the steering servo and that the spray foam someone put in the front was adsorbing water.
    So i switched to a waterproof servo and scraped out the foam and put in some waterproof foam.
    The next thing to go was the battery trays.
    Well the u-joint finally broke so its time to get rid of the out-drive and i decided to go with the SS hardware.
    Tomorrow i will be sanding the blue paint off to prep for the new glass work and paint job.
    Last edited by Camaroracer; 06-29-2011, 10:38 PM. Reason: added battery tray removal
  • Camaroracer
    • May 2011
    • 22
    Damage from the previous owner
    Just after i got the boat and put a Traxxas 2.4 rx in it
    Removed the Rx box and Installed a Traxxas waterproof servo
    Took off the stickers and hardware to sand and prep for paint
    • tiqueman
      • Jul 2009
      • 5866
      Congrats on the buy. The BJ26 was my first real FE boat. Be careful, the addiction comes quick.
      Tape your hatch all the way around and you will likely never get anything wet again. And you wont lose a hatch. Dont trust those magnets. Clear vinyl electrical tape or hockey tape works very well.
      • Camaroracer
        • May 2011
        • 22
        Thanks and i have the addiction already im up to 12 or more rcs.
        I had tape on it just not enough and when the boat skipped the third time it pulled the hatch off and down she went.
        I love your hatches btw
        • tiqueman
          • Jul 2009
          • 5866
          Yeah Ive had the addiction since about '86 when I was 10 yrs old. My FE boat addiction began in early 09 and Ive got more than I want to admit to. I sold a bunch of them a few months ago and still have a shelf and rack full. My problem is, I sell one and buy 2.
          thanks!
          • Camaroracer
            • May 2011
            • 22
            Well i spent 2 hours sanding on the boat and got the first 2 grits done and almost all the blue paint level with the white. Im hoping to get to work on it some more Saturday. There are actually some spots that i have to build up with epoxy or something else.
            • Camaroracer
              • May 2011
              • 22
              The hardware came in today
              • Camaroracer
                • May 2011
                • 22
                What is the best thing to use as a filler on the fiberglass?
                • tiqueman
                  • Jul 2009
                  • 5866
                  I use a product by Adtech called P-78. Its made specifically for that exact application. Handles flex and what not, unlike some auto body fillers. Ive also used marine-tex and it works well too. And is easier to find locally...
                  • Camaroracer
                    • May 2011
                    • 22
                    Thanks ill try to find the p-78 tomorrow if i cant ill just order it
                    • Camaroracer
                      • May 2011
                      • 22
                      Should i leave the liner long or cut it?
                      • tiqueman
                        • Jul 2009
                        • 5866
                        How does your strut and strut bearing fit with it like that? If it doesn't interfere, you could leave it. Personally I would cut it flush or and eighth out. Leave a little out one or both ends so I can more easily be removed if needed.
                        • Camaroracer
                          • May 2011
                          • 22
                          It fits perfectly at the end of the flex shaft so ill probably leave it alone for now unless there is a problem with it that way
                          Tomorrow i should get all the stuff i need to fill all the holes in and secure the stuffing box./
                          • Camaroracer
                            • May 2011
                            • 22
                            How far off should i offset the rudder?
                            • Mr.rc
                              • 13
                              I'm doing the same thing right now lol... is the blue hard to get level with the rest of the boat????
                              R2 Hobbies GodSpeed U Catamaran, WidowMaker 22, custom Rustler VXL,
