What Prop you guys using???
  • CATsasstrophe
    • Dec 2007
    • 5
    Hey guys, new at this fast electric stuff and R/C boating in general. Wanted to know what props you guys are using on the BJ26. I am seeing alot of x642 and x645 as well as 440's. What do you guys recommend? Also some guy tried to sell me an m435/3, is that any good?
  • obrien
    • Nov 2007
    • 1264
    I would think the 435 is going to be a bit small in diameter, but I haven't tried it yet. If you are running the stock motor on nimh batts, I would say to give the M440 a try. I have the ammo 36-50-2300 in right now, and I am running a detounged x642. The 645 is a bit slower so I would say that it is just a bit too much wheel for the motor to pull. Maybe on lipos you could get away with the 645.
    • CATsasstrophe
      • Dec 2007
      • 5
      sorry, I forgot to mention I am running lipo's with the stock setup. So I guess I can try the x642. What do you mean by the x645 being slower? I am still a little ignorant on all this prop stuff.
      • obrien
        • Nov 2007
        • 1264
        well with my ammo motor setup, the boat went 49.1 with my 642. when I put on the 645 it only ran 47.3 mph. Try the 642, but i would suggest removing the tongue on the blades. Just by doing that my boat went from running 37.xx mph to 49
        • CATsasstrophe
          • Dec 2007
          • 5
          OMG!!! big difference. I will try the 642. Thanks for the info. Is it a mission to remove the tongue?
          • RCprince
            • Jul 2007
            • 1637
            Dumb question, but how do you remove the tongue, whats the right angle of approach.
            Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
            • ReddyWatts
              • 1700
              The next to last post on this thread shows two props the (M) on top of the other (X). You can see the small difference in a an X and an M prop.
              Prop Tongue
              ReddyWatts fleet photo
              • RCprince
                • Jul 2007
                • 1637
                Your a godsend Reddy.
                • obrien
                  • Nov 2007
                  • 1264
                  I just took a right angle air grinder to knock the tongue off, and then sharpened and balanced it again.
                  I know alot of people won't do this, but I put a piece of 500 grit sandpaper on my right angle grinder to sharpen and polish my props. But now that I have a dremel, I will just be using that.
                  • RCprince
                    • Jul 2007
                    • 1637
                    I just detongued my 645....lets see what happens...also trued the bottom of my hull to look like this check the pic
                    • obrien
                      • Nov 2007
                      • 1264
                      lol, I wish I could own that beast!
                      • RCprince
                        • Jul 2007
                        • 1637
                        I wish I could own that or this one to But the Bud select has a better profile, that hull is made here in Florida..Deland I believe just 15 minutes outside of Orlando.
                        • obrien
                          • Nov 2007
                          • 1264
                          I know the driver of the Miss Geico. mark granett. or however you spell it. there is always the Miss Longlite with turbines.
                          • RCprince
                            • Jul 2007
                            • 1637
                            Yea Mystic power boats in Deland, fl makes , the BudSelect (Red on Black and Black on Red one, not the one with silver in the color) Callan and Miss Longlite http://www.mysticpowerboats.com/
