charger
  • macerov91
    • Apr 2010
    • 54
    charger
    i was going to get this charger because it charged two batterys at the sametime and was cheap i thought. but all the reviews seem like it is hard to use. so can anyone tell me another one that charges two lipos batterys and has some kind of screen on it? and yes i am a first timer at all this stuff and have been looking for just the right one for along time. any help would be just fine for me. thank you!!!!
    this is the one that i was going to get
  • CatMan
    • Jun 2010
    • 96
    I am new to this as well, but I got an 8cell charger, balancer and a "splitter" board plugged into the balancer, that will let me charge 4 2cell batteries at a time,or any combination up to 8s. like 2 3s and 1 2s, or 1 5s and 1 3s and so on. dont know what the splitter thing is called, but I did the same as you at first looking for the dual output chargers. then came across the splitter option. your link didnt work, so I dont know which charger you are looking at. I liked what I read about the chargers they use at hobbyking that are simple : hexTronik Balancer/Charger Dual Charge Capable (JST-XH Plug) you can charge 2 2s packs with this charger, dont know anything else other than what I read @hobbyking. Hope my attempt to help actually helped
    • macerov91
      • Apr 2010
      • 54
      does this link work?
      yeah samething here i might just give them a call!
      • gizmo1
        • Dec 2010
        • 272
        This is a very nice dual charger set up, a bit pricey though. http://store.rcsupersales.net/servle...sh-DUAL/Detail
        I was turned on to these by another member and just bought 2 of them to charge 2 packs @ a time, saved enough money to buy 2 more battery packs in the process, this is very simple to use charger with a built in power supply, it also works off a 12V battery.
        Hope this helps out,
        Giz.
        JAE21 Rigger, ML Boatworks PS 295 Tunnel , TS3 FE Tunnel , H & M No Step 3 Mono , H & M Skater , Wildcat EP , Rio EP .
        • CatMan
          • Jun 2010
          • 96
          Yes your second link works! looks like a nice one and im guessing you could split each output and charge up to 8 2s lipos at a time! and Gizmo's 1st one is too pricey for me but I like the 2nd one. and if im wrong about these splitter things, I hope someone corrects me! but with the Thunder AC6 charger couldnt you plug a splitter into it and charge 3 2Slipos at a time?
