Here are some major mods I did to my Black jack after I burned my stock esc, The cooling case is reusable and excellent...I Modified the stern and the sponsons
Things you do when bored!
Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
And the last set of pics no particular order.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
I used a 100amp suppo esc and I used balsa wood for the changes.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Thanx Avanti, I'm working on another modification, my cousin bet me I can't get this hull to 60 mph...Christmas money for me.....I got it to 52 and not at full throttle....Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
I was running a ammo 2600, with a 4500 6s and an Oct x645Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Well in our fleet we have 2 SV one out board, the inboard one did 47.7mph, the outboard with the BJ stock motor did 38mph the blackjack which did 52mph and the Jolly which did 64 mph...these speeds are just trial speeds, we are still learning about cg and proper prop selection. our next Build is a maritimo or an hpr 115 and a christo 03....Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
I'm rebuilding the stern of the Bj gonna try some tabs and see what happens...I have a need for speed. I'm also trying to figure out what runs better on cats a flat bottom or half vee bottoms like the real ones.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
