BJ BL Esc
  • domwilson
    • 4405
    BJ BL Esc
    It looks like the ESC can handle 16 cells. What do you guys think?
    By the way, Will this fit an Octura Prop with a 3/16" bore? I mean the prop shaft, not the ESC.
    Government Moto:
  • SJFE
    • 4735
    Nope. They use a 1/8th shaft.
    • RCprince
      • Jul 2007
      • 1637
      The BJ fits any 3/16th hub size prop once you use the Brass bushing, I ran mine with 18 cell and yesterday morning I ran it with a 6s 4500.....needs a little more weight though, it was a plane, it starts to go airborne and flip backwards at 52(gps).
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • SJFE
        • 4735
        Witch is it? Did you 18 Nimh or 6s lipo?
        Is that a 3mm shaft?
        • RCprince
          • Jul 2007
          • 1637
          I used both...I borrowed one of my cousins 6s for a test run it performed well, just a lil' to light in the bow for the speed, next I'll try 2 6s in parallel.
          • RCprince
            • Jul 2007
            • 1637
            On the shaft I did like what diegoboy did and ran a .150 octura flex shaft kit...works flawless, with no vibration unlike the universal joint. and on the shaft , it's either a 1/8 or a 3mm which ever is bigger, just not a 4mm.
