Roadrash's boat project
  • dana
    • Mar 2010
    • 3660
    #31
    Originally posted by roadrashracing View Post
    I have never setup hardware before so I don't know how it will preform, it seems to be a fudge off or is it right?
    did you get some 7/32 brass with the unit? seems like you have cut the stuffing tube a little short but no biggie. if you have some 7/32 you can use it to bridge the gap from the stuffing tube to the strut housing. just cut a piece an inch long, put a drop of crazy glue onto the outside of the 7/32 and insert it about 3/16 into the stuffing tube. now the other end should slide right into the strut housing. thats what i did with mine
    • roadrashracing
      • 1630
      #32
      I did but my tube is the same size if not a little bigger
      • dana
        • Mar 2010
        • 3660
        #33
        The blackjack stuffing tube is 1/4 inch... The 7/32 slides rite in snug
        • roadrashracing
          • 1630
          #34
          guess I'll try removing some paint
          • dana
            • Mar 2010
            • 3660
            #35
            No the 7/32 goes inside the stuffing tube
            • roadrashracing
              • 1630
              #36
              sorry I'm just not see it, I had the peice of stuffing tube I cut off, I cleaned it out, I even sanded down the end of the brass tube but it will not go in.
              • roadrashracing
                • 1630
                #37
                then what do you do with the hull side?
                • dana
                  • Mar 2010
                  • 3660
                  #38
                  listen very carefully.... the stuffing tube in your boat is 1/4 diameter . you should have a 7/32 diameter tube you got with your ose strut. yes? take the 7/32 brass you got from ose and slide it into the 1/4 stuffing tube on the boat
                  • roadrashracing
                    • 1630
                    #39
                    i THINK i GOT IT AFTER GRINDING THE END OF THE BRASS DOWN AND REMMING the stuffing tube it was a tight fit.
                    • roadrashracing
                      • 1630
                      #40
                      Well it was a pretty good day, got all the hardware buttoned up
                      • G-UNIT
                        • 971
                        #41
                        open the gap a wee bit more.
                        • roadrashracing
                          • 1630
                          #42
                          Boats ready for just a lot of wind for the next few days. Will I need an extra water pick up?
                          • G-UNIT
                            • 971
                            #43
                            Only if you think your components are getting to hot.
                            • roadrashracing
                              • 1630
                              #44
                              Going to try it tomarrow
                              • roadrashracing
                                • 1630
                                #45
                                2nd run today, still cold, a little windy but boat ran great, it did take a lot to get on to plane at times.
                                video http://www.flickr.com/photos/3897564...n/photostream/
                                Hard to drive and film at the same time
