how to set you program card?
  • macerov91
    • Apr 2010
    • 54
    can someone please tell me how to set my program card so i can waste the gas powered today!!
    i have just the reg proboat batterys and the new prop. i know i need to lipos but haven't got around to it yet. please help!
    i have the problem where the boat shuts down during full throdle.
  • WrknItUp
    • Jun 2010
    • 391
    typically with lipos setting would be,
    Battery type: lipo (in your case Ni-mh)
    Cutoff voltage:high (set yours to low)
    Cutoff type: Slowdown
    Brake: Off
    Timing: High (set yours to low)
    Throttle curve: Linear (set your to logarithm)
    UPDATE TO LIPOS ASAP! Makes a day and night difference!
    I believe it's my god-given right, To destroy everything in my sight. Cause it never gets dull, it never gets old. The only thing it gets is more bold. Drinkin', fightin', going to the game. In our world it's a way to stay sane. If you're asking me. To have it my way, I'd say that's One fine day. ---- The Offspring
    • macerov91
      • Apr 2010
      • 54
      thanks buddy! i'll post the video tomorrow maybe
      • macerov91
        • Apr 2010
        • 54
        oh yeah and what do i do with it again? which one do i discounet and hook up to the programming card i lost the paperwork?
        • WrknItUp
          • Jun 2010
          • 391
          Make sure you read the Program card manual, Some of your setting are not letting you get the full potential of your setup!. Due to Nimh batteries you cant run everything wide open. So you have to tone it down a bit to make sure the batteries don't keep spiking the low volt cutoff! Thats why u cant run wide open for long periods of time if at all.
          • WrknItUp
            • Jun 2010
            • 391
            The red brown and black from the esc go on the right side of the card. Ill send you a link to the instructions.
            THE BROWN WIRE FACES YOU (or the metal pins face up)
            • macerov91
              • Apr 2010
              • 54
              so what would you say i should do today?
              • WrknItUp
                • Jun 2010
                • 391
                Buy lipos... Lol. Um you can still run it, Its just not going to be as fast. On the other hand it will run longer and i think you will be able to achieve full throttle, just not 100% full. About 80% Set it up on the card like i posted and try it out. What size prop are you running? The prop size says alot when it comes to full throttle amp draw too. Im trying to find the manual and having a brain fart!
                • macerov91
                  • Apr 2010
                  • 54
                  x642 prop
                  • WrknItUp
                    • Jun 2010
                    • 391
                    Yeah thats not much relief compared to the stock prop. Yeah run with the settings described. I cant find my sheet or a link to the card instructions even. Hopefully a passer by will send there link! Upgrade to lipos as soon as you can and make sure you get a good charger too. READ ABOUT LIPOS THEY CAN BE DEADLY! so they say lol i just say it to help make people read about them and understand what kinda power difference they provide and all the security measures to them!
                    • macerov91
                      • Apr 2010
                      • 54
                      sounds like a plan! which ones do u have and what charger?
                      • roadrashracing
                        • 1630
                        I just got a card today, I had a question about what kind of motor is stock? Is it 2,4,6 pole, can run high timing for stock motor if you are running lipos? I can scan the manual if anyone needs it.
                        • roadrashracing
                          • 1630
                          better yet heres a link:
