Full Flex Shaft
  • Diegoboy
    • Mar 2007
    • 7443
    Full Flex Shaft
    I pulled the stock shaft, drilled out the outdrive, Installed a brass bushing, Installed the Teflon liner, Installed the .130 flex shaft with a 3/16 stub shaft. I didn't stop there...
    I pulled the motor, radio, & ESC, Installed the Ammo motor 2300kV (as opposed to 1500-1606kV stock), CC Baracuda 125, Novak XXL & an X645 prop.
    Yes, I know the steering linkage isn't attached!
  • webdr
    • Oct 2007
    • 30
    Nice. Did you run that prop on the stock motor/esc?
    http://www.gunnphotoservices.com
    • Diegoboy
      • Mar 2007
      • 7443
      Thank you!
      No. I never ran the stock power plant. It's up for salein the swap shop... FYI
      • Spoolin
        • Oct 2007
        • 26
        how fast are you trying to make that puppy go?
        looks nice
        • Diegoboy
          • Mar 2007
          • 7443
          looks nice
          As fast as my funds will let me.
          • Spoolin
            • Oct 2007
            • 26
            i want to see some vid
            • Steven Vaccaro
              Administrator
              • 8932
              Why pull the stock power so soon?
              Steven Vaccaro
              • Diegoboy
                • Mar 2007
                • 7443
                Only because I know the Ammo motor well, and I know it'll perform better. Plus the stock power system is more desirable when it's New!
                • Steven Vaccaro
                  Administrator
                  • 8932
                  Good point!! But I would have given the esc a beating. It looks pretty robust. But we all know looks can be deceiving.
                  Steven Vaccaro
                  • lancel
                    • Jul 2008
                    • 2
                    Diegoboy - I made several runs today adjusting COG and after about 5 minutes the U-Joint/Coupler gave out (pin is gone and one of the holding knuckes is snapped off. Rather than replace it with stock, I am keen to know where you purchased those Flexshaft components as I'd like this not to happen again and the flexshaft seems the way to go.
