8 awg on deans
  • G-UNIT
    • 971
    8 awg on deans
    Had to attatch connectors to zippy flightmax batterys, what a pain in the a*s
    8 awg.
    Managed to do it but one battery when put on the charger saids no battery connected. whats up with that, I put a meter on the battery and got voltage through the connector. tryed to clean the connector with electrical contact cleaner,
    no go.
    I am going to unsolder and resolder with another deans and see if that helps.
    I hope I didnot get a bub battery from hobbyking.
    Has anyone had this happen to them.
    Charger is a hyperion EOS606I AC/DC.
    The charger works fine as I charged two batterys so far.
  • kookie_guy
    • 900
    8 awg.
    no go.
    deans are terrible for not making good connection. bullets are the way to go. Solder joint is probably fine, but the blades in the connector are not touching well enough.
    • G-UNIT
      • 971
      Yea I was going to use bullets but the guy at lhs said I would have awhole lot of connections
      with the way the batterys are set up in series, stock wiring, I don't mind the deans it's just that the wire on those batterys are so large, I think I just got the the deans to hot.
      • JimClark
        • 5913
        Use Bullets
        Billy Graham
        • G-UNIT
          • 971
          Does anyone ahve pictures of the wiring useing bullets and keeping everything neat.
          I'll probably switch in time anyway, just need to see this boat running on lipos.
          what size bullets 5.5 4.4, remember the size wire on the lipos 8 guage big wires
          what size bullets from the esc and y harness
          • JimClark
            • 5913
            Personally I would get as big as I could to adapt to 8GA wire
            Billy Graham
            • JimClark
              • 5913
              Billy Graham
              • snaychev
                • Dec 2009
                • 53
                It is very easy to solder the Deans! Just hold the iron tip between the connector and soaked wire! Even with 40 watt soldering iron it is not a problem:
                I did mine before two days. Same zippy flightmax 2s 4500 mah
                I start from there, where the engineering thought intend to stop. The sky is just a border between
                • G-UNIT
                  • 971
                  Having diffucult time tinning the 8 gs wires and have to start all over again, now the wires are getting shorter and shorter, starting to pull may hair out.
                  • kookie_guy
                    • 900
                    You gotta preheat the wire pretty good before you tin it. If you are worried about the heat getting to the batteries, just wrap a cold wet towel around the base of the wire (where it goes into the battery). But again, don't waste your time with deans. The more you put them on and off, you will wear out an area on the blades, and have connection problems in the future. All my old NIMH packs have this problem now. I use 6mm bullets on everything now.
                    • LiPo Power
                      DJI Drone Advanced Pilot
                      • 3678
                      Swich to bullet connectors.
                      I have done it on all my boats.
                      Check here:
                      http://www.hobbycity.com/hobbyking/s..._(10_pairs/set)
                      Canada
